I got movie who came in avi format,but the subs files are .sub/.idx
Can somebody tel me a i can convert the movie with the subs using svcd2dvd
I already doing them using another converter who do .srt and .sub/.idx
Thanx in advance
Claude
Hi Claude,
Here's two options for you:
You can use ConvertxtoDVD to encode an avi with .sub/idx files to DVD.
Or you could "hard encode" the subs using avi recomp and then convert with your Mpeg encoder of choice.
Hope this helps.
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
To Moonstomp
Thanx m8 this is the way i am doing it at the moment,also that prog encode a avi file to dvd with sub on srt file or sub/idx file in superb quality in 1/2 the time for svcd2dvd to do a normal avi to dvd.also will convert almost any video files to dvd format.
Claude
Please help, problem adding assets to svcd2dvd
By stevea99 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 6th Mar 2011, 17:05 -
Adding subs.
By Ytrix in forum SubtitleReplies: 2Last Post: 21st Oct 2010, 12:39 -
svcd2dvd ffmpeg has stopped working adding dvr-ms
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 10:00 -
Adding subtitles to an SVCD2DVD project :shock:
By bxmbxm in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Aug 2009, 11:54 -
Adding Subs
By Russo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 21:45
