Hi,
What software should I use to burn a dvd from a ripped dvd in HD ?
I managed to rip a dvd (using dvdfab decrypt) to my HD and when I tried using CDBurner XP Pro to burn the dvd, I wasn't able to play it (on my PC) even though there's no error in the burning.
What did I do wrong? Any recommendation for a dvd burner (freeware)?![]()
Sorry I newbie in this.![]()
Thanks !
Results 1 to 11 of 11
If you read the manual, CDBurnerXP states that its Video DVD burning abilities are shaky, at best. steveryan is correct - ImgBurn (v 2) is the best for this task.
/Mats -
ok... need some advice here...
i've used dvdfab decrypter to rip a dvd to my HD... after ripping, there are 2 folders created (AUDIO_TS & VIDEO_TS)...
i've just installed ImgBurn and i'm not able to burn the dvd with both these folders intact like the original dvd...
anything i missed??...
thanks ! -
Just drag the VIDEO_TS folder into ImgBurn, it will create the AUDIO_TS folder for you. Is the VIDEO_TS folder under the single layer DVD-/+R limit? If it's not you will need to shrink or remove unwanted parts. Check this excellent guide http://www.digital-digest.com/articles/RipIt4Me_DVD_Shrink_Quick_Backup_page3.html
He's a liar and a murderer, and I say that with all due respect. -
Very good, glad it helped
It's free ImgBurn
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
