No matter what I do, my PSP always says "No videos"
what folder do these mp4s go into on the memory stick?
Nowhere in the docs does it say where they go.
I am using Super to convert the videos to PSP format, H.264 codec and 320x240 resolution.
TIA
TANSTAAFL
SUPER tries (in the output directory) to create copies of the directories where the videos will go. For example, videos that go in:
(Memory Stick root folder)\MP_ROOT\100ANV01\
...may be in (SUPER output folder)\MP_ROOT\100ANV01\ .
(Or maybe simply (SUPER output folder)\100ANV01\ .)
Likewise, videos that go in (Memory Stick root folder)\MP_ROOT\100MNV01\ may be in
(SUPER output folder)\MP_ROOT\100MNV01\ (or possibly like above, simply \100MNV01\ .)
Either way, create
\MP_ROOT\100ANV01\ and
\MP_ROOT\100MNV01\
...on your Memory Stick, if they don't already exist, and move the files to the equivalent directories. (Each of the above directories is for a specific type of PSP MP4 video format, but I don't remember which directory is for what format, offhand.
As a last resort, if the movies don't play on the PSP when you put them in the equivalent directories on the Memory Stick, try creating a directory named VIDEO in the root directory of the Stick (if it doesn't already have the directory), and moving the videos to that directory.If cameras add ten pounds, why would people want to eat them? -
Thanks,
I figured out last night after I posted that it goes in the other folder, like you suggested. I do appreciate the response, however.
ThanksTANSTAAFL -
wait all of what you just said right there not working i'm using mp4 format can you help?
What are you using to create the videos? I think the PSP can be picky about MP4s. Also, is your PSP's firmware completely up-to-date?
What folder are you attempting to place the videos in, on the Memory Stick?If cameras add ten pounds, why would people want to eat them? -
Hi,
Can you please tell where would i find the videos once i have downloaded them from the internet. I have started using a PSP from today and have not downloaded any firmware etc.I have simply gone on to a site and clicked on a video after which it asked me whether i want to save it, to which i said yes, and then it took me to a location to save the file and i chose "video" as the location and it started downloading. But, after the download was complete and i went to the video folder in my psp, there was nothing.
Where do these videos go. Or do i need some software to download and then save them ? Please help.
Test the memory stick
By alintatoc in forum ComputerReplies: 2Last Post: 13th Jun 2011, 13:52 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31 -
USB memory stick recommendation...
By retroborg in forum ComputerReplies: 5Last Post: 12th Sep 2007, 06:55 -
Corsair Memory Stick Troubles...
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 12th Jul 2007, 09:16 -
Memory stick?
By bevills1 in forum ComputerReplies: 2Last Post: 4th Jun 2007, 09:10
