I'm using TMPGenc to try and convert my DivX to an XSVCD NTSC file, but everytime I do it, the picture seems to come out all screwed up. I'm just wondering if anybody can tell me the settings to have for the following sections:
1) Profile & Level
2) Video Format (I'm guessing its the way I want my movie to be, but just making sure)
3) Encode Mode (I'm guessing Interlace, but again, just making sure)
4) YUV Format
5) DC Component Precision
6) In the video tab: should Aspect Ratio be 1:1 or 4:3?
and finally, should motion search position be on Highest Quality?
Everything else I'm setting seems to be ok (constant bitrate, full aspect ratio, 1:1 vga for source aspect ratio, 29.97 fps, etc.) if anybody can help, please do. Thank you.
If what I'm doing is completely wrong, then plz include the steps on how to make a correct XSVCD because the instructions are unclear.
What resolution are you using with that framerate?
What bitrate are you set at anyway?
That's a wierd resolution, you mixed NTSC and PAL together or something?
Use 704x480, which suits the NTSC 29.97fps. -
Its not weird look at http://www.vcdhelp.com/xvcd.htm
THis are the specs... for XSVCD
XVCD NTSC
Video:
up to 3500 kbit/sec MPEG-1
352 x 240 pixels, 720 x 480 pixels
29,97 frames/second
(23,976 frames/second NTSC Film)
Audio:
224 kbit/sec MPEG-1 Layer2
Extra:
Menus and chapters
Still pictures in 720x480,352x240
XSVCD NTSC
Video:
up to 9800 kbit/sec MPEG-2
720 x 480 pixels
29,97 frames/second
with up to 4 Subtitles
Audio:
32-384 kbit/sec MPEG-1 Layer2
with up to 2 Audio Tracks
Extra:
Menus and chapters
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
