    Oct 2006
    I have 25 episodes of a TV show in Xvid format. Each episode is 350 MB.
    I tried fitting these 25 into 2 DVD-Rs, 4.7 GB, however, only 12 episodes fit on each one, leaving 1 episode hanging...
    soo , i was thinking of maybe shrinking the size of one of the episodes to less than 300 MB, so I can then have enough room to fit all 25 episodes onto 2 DVD-Rs.
    So, question is, what is the best way to reduce the file size of an xvid ?
  2. Originally Posted by pj94z
    Reencode with a lower bitrate. Use VirtualDub in Fast Recompress mode. Image quality will suffer of course.
    You might also try cutting of opening and closing credits without reencoding. Use VirtualDub in Direct Stream Copy mode.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You have only one choice - re-encode it with a lower bitrate. The question is, do you squeeze one episode really hard, or 13 episodes by a smaller amount each ?
    Read my blog here.
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You might go through the eps and cut out or abbreviate credits or title sequences. Over 12 eps you'll probably save enough to fit the 13th.
    And/or you might demux the sound and save that at a lower rate. Most TV shows don't require high fidelity.
  5. Backup on 2 DVD DL (Dual Layer) 8.5gb each.
    without losing quality
  6. Banned
    Sep 2006
    China
    I think SPAM.
    Oct 2006
    OK guys, thx for the replies.
    I was planning on squeezing 1 episode and leave the other 12 alone - they are very high quality xvids of HD video, looks really awesome.
    If I can squeeze one episode down from 350 mb to maybe 300 MB, I think it would all fit on ONE DVD.
    Or, I may just get fed up and use a 3rd DVD and burn one single episode to it lol
