I just got my first dvd burner the otherday. So i am wondering how many videos can you fit on a dvd+r 4.7gb. I have gotten upwards of 2 1hr and 30min videos. But i was seeing if there was a way to fit more. Like differnt encoding software. Right now im using nero with AVI files. Is there hope for me?
im getting alittle lost with all of this. What is the best or the easist way to do this. They are divx avi.
If you are encoding to Divx, you are using the DVD as a data disc. Many full length movies have been encoded to Divx or Xvid to fit on a CD of about 700MB. A DVD holds about 4.37GB, so you can easily get six of those on a data DVD.
The easiest or best, depending how you look at it, is to use a program like AutoGK, or FairUse Wizard, or avi.net to create the Divx or Xvid. This is usually from a DVD that has been decrypted. If you raise the compression higher or lower, then that will change how much video you can put on a disc. And it will also lower or raise the quality. If you are encoding shorter clips, I find VirtualDub works well.
Or if you are wanting to play the files on a regular DVD player, not a Divx DVD player: You would need to encode them to DVD video and audio specifications and author them to DVD format. Then you might get up to about 8 hours of video, but at greatly reduced quality, about like a VCD. Good quality, about 2 hours. The DVD format is to the upper left, under: 'WHAT IS' DVD. <<<<<<
And welcome to our forums.
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 7Last Post: 26th Jan 2011, 22:25 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
How to make a compilation of 4:3 videos and 16:9 videos together on a dvd?
By pedrotc2002 in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2010, 18:35 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13 -
How can I fit more then 3 Videos/181MB Each on a 4.7GB DVD!!
By Tielurr in forum Newbie / General discussionsReplies: 6Last Post: 26th May 2007, 00:25
