Hello all,
I put together an HTPC system comprized of P4, 2.4 GH w/512 MB RAM, and 80 GB hard drive I had lying around. I purchased a cool/quiet aluminum HTPC case with 450w PS, an AGP, XFX 6800XT 256 MB video card, an AuzenTech HDA X-Plosion 7.1 DTS Connect sound card and an LG GSA-H10L DVD ROM burner.
Got the timmings/reolution set to fit my JVC 52" HDILA perfectly with no overscan.
Plays games like a champ; Doom and Quake look awesome with pretty high settings.
The problem is no matter what i do it just wont play a movie.![]()
When trying to read a DVD the system resources go to 100%, slows way down, and the only way to get it back is to end task and that can take quite a few minutes just to end task it's so slow.
Ive loaded TheaterTek, Zoom player, Nero, Power DVD, set IDE controllers to DMA, upgraded win 2k to service pack 4, Explorer to 6.0, Direct X 9.0, updated DVD firmware, tried another DVD drive.....
Iv'e dumped the hole system twice and reformatted the system from scatch with just the minimum loaded.
Zoom player has a feature that tells you what (DVD Decoder) is missing, you klick on it and it takes you a place to down load it, I did all that. With No luck.
If nothing else I feel better now that I got all this off my chestbut I t sure would be cool if I could play DVD movies.
Any ideas anyone?
Results 1 to 21 of 21
How are you feeding the computer monitor and/or HDTV?Originally Posted by pvbj
If it is a TV (YPbPr, S-Video, etc.) read the ATI instructions on setting "Theater Mode".
Edit OOps: I was dyslexic and read 6800XT as 9800XT.
You need to read the overlay instructions from NVidia which can be tricky in dual monitor mode. -
The 6800xt has dual DVI and one what they call TV out: S-vid
I'm using the DVI. -
It's all about getting overlay set correctly.Originally Posted by pvbj
Good point. VLC is a self contained software solution. PowerDVD should include a MPeg2 decoder as well but pvbj may not have loaded it. Depends whether it was on the DVD-Rom install CD or was a on the CD that came with the retail version of PowerDVD.Originally Posted by Baldrick
A black window indicates a display card overlay issue. High CPU % indicates hardware MPeg2 decode assist may not be selected in the decoder preferences. -
And.......What..........exactly does that mean?
For what it's worth, I have taken it off the tv and currently have it connected to a 19" VGA monito via VGA/DVI adaptor. -
It means download and install this and try to play your Mpeg file.Originally Posted by pvbj
https://www.videohelp.com/tools?tool=VLC_media_player
http://www.videolan.org/vlc/
Let us know if it plays on the computer or HDTV monitor. -
Actualy thats another weirdness.
Zoom Player (if you are familiar) has the capability of selecting what ever video decoder audio decoder installed in the system but the only ones that show for the most part, are FFDshow ones, not that htey work. Ive loaded DScaler also.
Needless to say I'm not sure whats going on. I just keep loading and dumping stuff in an effort to get something that works. -
I am not sure of much edDV, but I down loaded VLC and will give it a go when I get home.
Is there anything I need to do prior to launching VLC? like remove programs or whatever?
When I installed FFDshow I checked the box for MPeg2.
Should I only enable MPeg2 type decoders?
Could I be enabling to many? -
Well I installed VLC and it slows the system down quite a bit but if I wait long enough I get some sound.
Havent found VLC test you mentioned yet, where might I find such a thing.
Something I forgot to say is the dvd reads are real low when benchmarked like .78 MB/s -
Does anyone think a bad IDE cable could cause these sort of symptoms
Yes thank you edDV,
A CD of a video from my digital camera, AVI I believe, plays on Windows Media player okay but I can't play the same video in VLC.
I looked in preferences and could not locate hardware acceleration tried checking advanced option still cant find it.
Sorry edDV, Please bare with me.
Thanks -
Did MPeg2 from a DVD play? That was the test.
Digital camera video is likely to be MJPEG, Quicktime or MPeg4.
MJPEG should play in VLC.
Sorry, i was thinking of a different player. Use default hardware settings (found under DirectX-advanced). No need to make changes.Originally Posted by pvbj -
No MPeg2 did not, just got a black screen and had to end task.
Is there a way to verify the presents of MPeg2 decoder?
Do you think it could be hardware related? MOBO bios upgrade, or a jumper or something.
I removed all related programs including VLC and reinstalled VLC just incase.
Same thing.
Not sure why the video camera video would'nt play in VLC. It's on a CD not a DVD disk, i selected open disk and changed from DVD to VCD still no luck. It plays great on MP.
Does MP play MPeg2? -
Last night I noticed a problem with a usb contoller in Device Manager.
Tried searching for a driver a few times with luck so went on the ASRock sight and found a driver update in addition to the USB driver thy had an Adio, INF, and LAN driver, so I went ahead and updated them all.
Whalla movies work!!!
Both VLC and Zoom player work great.
Not sure if it was getting rid of the USB conflict/problem or one of the other updates but I'm as happy as a clam.
thanks for all you help.
Next is HDTV tuner card
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 22:32 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
can my htpc have a better interface other than mpc-hc? and still play mkv?
By craig198 in forum Media Center PC / MediaCentersReplies: 13Last Post: 20th Dec 2010, 20:28 -
Best file format to play on Windows HTPC
By waynezo in forum DVD RippingReplies: 4Last Post: 21st Nov 2009, 16:25 -
htpc play music video software
By scorpio1959 in forum Software PlayingReplies: 2Last Post: 5th Jul 2009, 07:00
