Whats the best way to convert a 1080i sample clip to 1080P with minimum quality loss?
Files are in TS (Transport Stream) format.
your decoder will do it anyway -- if they have pulldown , remove the pulldown ... if they are true 29.97fps , leave them alone
Via AviSynth:
SeparateFields().SelectEven().Eedi2()
Requires EEDI2
http://bengal.missouri.edu/~kes25c/EEDI2v092.zip
That combo is pretty good, but I'm with BJ_M if you can avoid it.
1080i to 1080p
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Jan 2011, 06:38 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
Convert .TS 1080i into .TS 1080p?
By Lanford in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2010, 03:03 -
1080I camcorder or a 1080P
By zapper130 in forum Newbie / General discussionsReplies: 9Last Post: 16th Jan 2009, 17:44 -
1080i vs. 1080p
By Shibblet in forum DVB / IPTVReplies: 31Last Post: 27th Sep 2008, 14:24
