Hiya, i put this in the noobie forums, cause well i am a noob at this and i wernt sure if this topic had already been covered, sorry if it has..
I want to convert music videos to go on my mobile, so far i have used WINAVI converter, to convert a .MOV file into .3GP. It converts the video fine, but there is no audio, not even stactic or anything of that kind. Is there a way to solve this? if not, or if its a better option, what other program could i use? Thanks very much for any answer.
If you try converting the video to a different format, say, AVI, does the resulting video have audio? I'm not sure, but I noticed this during a quick read of the SUPER frequently-asked questions page (at http://www.erightsoft.com/faqt.html ):
Maybe the original 3GP video is using AMR-Wideband audio?* The Adaptive Multi-Rate Wideband (AMR-WB) speech codec is NOT supported by QuickTime.If cameras add ten pounds, why would people want to eat them? -
i M having a Kodec-360c(something) Digital Camera. It creates .mov files ... , But I m unable to hear them ...(Except VideoLAN). with p4-processor, xpsp2, QuickTime 6.5(Downloading 7)
Now I not-only want to hear it in normal player as well as burn them as normal VCD.
May be I m lacking some QuickTime support(codec).
Thanks! anyway.
trying Super and Total Video Converter ...
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
AVI2ISO sound problem
By Belfour in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2008, 14:37 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 19:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 04:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 07:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 21:22
