Using the Dazzle DV Bridge, 90% sure the analog capture is field order B. I edit this footage in Media Studio Pro using field order B in the all the settings (output is DVSoft codec). I then want to take that output and TMPEG it into an SVCD MPEG2.
What settings do i use in tmpgenc to accomplish this? SVCD playback is for a homeunit DVD player, so do I make an interlaced MPEG2, or some of these fancier 29.976 to 23.976 inverse techline, deinterlace yadda yadda yadda stuff.
Thanks,
Robert
DV Type-1 is always order A (or bottom as it is called)
since source is interlaced ... leave it interlaced , 29.97
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Project with mixed frame rates and resolutions - confused
By tarrickb in forum Video ConversionReplies: 4Last Post: 10th Aug 2009, 15:38 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 12:27 -
Still Frame and Field Capture?
By swingmaster in forum Newbie / General discussionsReplies: 1Last Post: 10th Mar 2009, 10:28 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 15:36
