Hi guys, sometimes i had some of the movies where some sites will pop up automatically every few minutes of viewing them. How can i stop that? Please advise. Thanks
Use real alternative together with Media Player Classic...if you are playing real media files.
The only way to get rid of the popup window short of uninstalling is to change your startup programs. For Windows 2000, there is a freeware program called startup (I believe). Someone can tell you how to do it for Windows XP. Everytime I use the Real Player, I have to change the settings, because the Real player reinserts back in the startup every time it is used. You can also go into Windows Task Manager Process tab, and turn it off after using the Real player, but you have to turn it off every time you restart your computer. Real Player is a real pain. I am going to try and use Real Alternative, and see how well it works.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic -
turn out playing the movie causing my com infected with trojan and virus..dam...
Did you download the movie? It could have been the cause of the virus. If you got Real Player from a site other than the real Real Player site, it too could have been the cause of the virus. Always use an AntiVirus program to check all downloads. I use AVG, which checks items while being downloaded. An AntiVirus program will not always help with spyware installed by programs.
Annoying adobe flash player pop-up
By visjds1 in forum ComputerReplies: 5Last Post: 28th Jan 2011, 21:32 -
Browser issue, need real help!
By alintatoc in forum ComputerReplies: 11Last Post: 2nd Oct 2009, 09:44 -
Will sending video from my TV through my vcr/dvd player get rid of lines?
By Darkstraw in forum Newbie / General discussionsReplies: 7Last Post: 14th Aug 2008, 23:47 -
Real Player Format
By Russo in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2007, 23:00 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
