    Oct 2006
    Philippines
    hello! . Is there any way on how to synchronize external subtitles without manually setting the time every scene? by the way im using mpc and vobsub.
    Nov 2002
    With Subtitle Workshop, you can do a "two-point sync". Basically, you find the time of the first subtitle, and the last subtitle, and the program will proportionally stretch/tighten everything in between. It's one of the advanced options documented in the help.
