I burnt a VCD and my Mustek V560 doesn´t play it. All my other VCDs are running on it. I used the same brand of CD-R.
On my PC the VCD is running without problems, but only with PowerDVD XP.
Look, that's like saying that you woke up one day and your car stopped working...
You will need to provide more information and details (e.g., how you made the VCD, how you burnt it) before anyone can help.
Regards.
Michael Tam
w: Morsels of Evidence -
My DVD-Player´s playing all my other VDCs without problems. Only the one I burnt with Nero (like all the others) out of a Nero image file (that´s the only difference) is only running on my PC and only with PowerDVD XP. I tried WinDVD, with the same result, that my DVD-Player had, it wasn´t running.
All the other VCDs I burnt (which are running without problems) were mpg files.
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem in VCD on WinAVI 9.0
By WhitGer in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th May 2008, 04:29 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
