Which DVD recorders are available in the US that can control a cable box?
I have an HP m7250n Media Center desktop that does a wonderful job as a DVR and controls the Scientific Atlanta cable box just fine. Which DVD recorders have that same capability?
Thanks for any info.
Bob
Panasonic DMRE85HS and the Sony RDR-HX900 both do - most of the better ones do it seems if you look at the specs
Is there a wireless device to control a cable box remotely and send picture
By MrBiggZ in forum Newbie / General discussionsReplies: 4Last Post: 5th Jan 2012, 19:18 -
Which remote control with IR blaster to use with Windows 7 Media Center?
By usually_quiet in forum Media Center PC / MediaCentersReplies: 5Last Post: 1st Sep 2010, 18:59 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 16:24 -
Control of Cable box via SageTV on Windows Media Center 2005
By Sierraguy in forum Media Center PC / MediaCentersReplies: 2Last Post: 8th Feb 2010, 01:31 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21
