I've just downloaded Rush Hour 2 [DVDRip ViTE DivX] and it works perfectly, but when I try to convert it with TMPGEnc I get no sound but I get a 4 hour long video that contains Rush Hour 2 (1.5 Hours) and a whole lot of nothing.. Just a black screen.
Can someone please tell my what I'm doing wrong??
Can't someone please just tell me what they think is wrong.. Is it the file, because I haven't had any problmes with other films so fare..
The video: Open TMPG, go to settings > advanced > source range, specify the start frame (0) and the end frame. Helps sometimes.
The audio: ..is probably compressed, I guess .mp3. TMPG don't like compressed audio. Open the DivX in VirtualDub, video > direct stream copy, audio> full processing mode /compression: PCM uncompressed. Save avi.
Load this new avi as Video source into TMPG.
Pray it works. Otherwise the the audio is probably VBR MP3.
At the moment I dont have a solution to decompress a VBR MP3 properly. Unfortunately the DivX crowd is very proud of the possibility of VBR audio encoding. -
You can try to extract the audio from the file with Total Recorder. It's only in Real-time, so it'll take forever. But it will most definitaly work. You will get a wave file at about 540 megs. Combine this with the video stream you already encoded in TMPEnc. This should solve the sound issue. Don't know about the video though. Try the solutions mentioned above.
Thanks to Doom9 we have a new avi to (S)VCD guide and you have probably a solution.
http://www.doom9.org/mpg/avi2svcd.htm -
if you convert the audio to a separate wav with virtualdub and then use it as source in tmpgenc it should work http://www.vcdhelp.com/virtualdubaudio.htm .....it works for both cbr and vbr audio....
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 05:51 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 10:18
