I wanna watch this TV show but because its encoded in h264 my computers graphics card cannot process it.
I am using an Intel Celeron 2.7 Gigaherts with 768mb memory but my graphics card is an AGP GEFORCE MX 4000 64 MB.
What kind of graphics card should I upgrade to? I'm considering a GEForce 6200 256mb, but I dont know if that will cut it... can someone help me out?
It's the decoding software that makes the difference. I'm convinced the Graphics Hardware hype is just that - Hype. Save the $$$ on the new Nvidia card, it won't make enough of a difference.
Spend $10 and install CoreAVC - https://www.videohelp.com/tools?tool=CoreAVC
This software WILL allow you to play h264 on your system.
You can even test it with the following app: http://haali.cs.msu.ru/mkv/timeCodec.exe
http://www.behardware.com/news/8117/coreavc-stronger-than-avivo-purevideo.html -
I would say the processor is far more intensive than the GPU would be.
Graphics Cards, though may contribute very little to video editing and playback, were mainly designed for one main purpose, "Gaming". -
This article may help as a background on the new cards.
http://www.anandtech.com/video/showdoc.aspx?i=2645 -
It's not the graphics card. I can play x264 back on a Celeron 400 MHz, but i'd only get about 4 fps. It's CPU and config.
The important bit is SSE2 support by your CPU, which is apparently a requirement of all of the h264 decoders.
http://en.wikipedia.org/wiki/SSE2 -
I run an Athlon XP 1900+, lists as not supporting SSE2 in the link above, and I decode h264 just fine. I use CoreAVC Standard Edition.Originally Posted by Soopafresh
So either the Athlon XP supports SSE2 or SSE2 is not a requirement.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
Need another graphics card already!
By A Traveller in forum ComputerReplies: 15Last Post: 26th Sep 2011, 17:07 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 16:51 -
Laptop processor/graphics card for x264, H264
By RickyRicardo in forum ComputerReplies: 2Last Post: 15th Jan 2011, 15:17 -
What should be a simple process is giving me grief - help needed!
By BertRito in forum Newbie / General discussionsReplies: 7Last Post: 10th Jun 2010, 18:56 -
What sort of Graphics Card/Capture Card to get
By Dr_trout in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 16:19
