i clone my tv in my pc using s-video and it works fine i can play movies but the prob is when im trying to play an avi file with separate sub like .srt the tv wont display the sub only video, but in my pc i can see the subtitle...
pls help me, what seems to be the problem here?
The subtitle information has to be encoded into the video signal for the TV to be able to decode the subtitles and display them. Subtitles (closed captions) are encoded on one of the lines of the video frame that are not visible (line 21). Unless you have a TV-out card that can encode the subtitles onto line 21, you won't ever be able to see them. The reason that the PC can do it is because the subtitles are stored in a separate file and the media player knows how to add the text on top of the video.Originally Posted by dotskieJohn Miller
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
