hey i use shrink 90% of the time to do my burning and its easy and great! now some of the dvd i come across wont allow shrink to put the files on my hard drive there for cant burn them! so i researched and downloded dvd dycrypter and that allows me to get it onto my hard drive! now from here im stuck!!!
i trie to re open it in shrink and cant becaus of the enycrypted file so its sitting on my harddrive and i cant get them off onto dvds! Now i Have NERO which is a really good burning program and i can make cds mp3s and SVCD's but have no idea how to use the files i allready have and NERO combined to burn it onto DVD!! Does anyone know how to?? and do i need to compress the files as DVD SHrink does on NERO? because i have a feeling that the file is too large when copying on DVD Dycrypter!! PLease please please help me :) much appreciated to who ever is the genious who can answer it :)
If you got it onto your HD, but it's still encrypted, you are using DVDDecrypter wrong!
Try Ripit4me (or DVDFab Decrypter + DVDShrink).
Also note that DVDShrink doesn't burn at all. It can launch other apps that can, but it doesn't burn itself.
Avoid Nero.
/Mats -
jno_6,
DvdShrink (by itself) can't handle the new copy protections they put on dvds specifically to keep you from making your backup. DvdDecrypter can't handle it either anymore (by itself). DvdShrink can't open the rip you did with DvdDecrypter because it's all messed up. That's why mats.hogberg recommended RipIt4Me (a freeware program). It can handle any copy protection, and let you get a clean rip onto your hard drive, so DvdShrink can work. If you use RipIt4Me your problems will go away...if you don't, you'll continue to have problems with some (many) dvds.
If you do decide to get RipIt4Me, save a copy of the guide from the website, too. You'll need it the first time.
You would also make your life easier, and your backups better, if you were to get a copy of a modified DvdShrink that lets you automatically burn with ImgBurn (also freeware). You can download it from here.
If you have any questions or problems, post back to this thread.
And since it's your first post, welcome to Videohelp. -
Thank you all for your help soooo much!! iv worked it out and its working fabulous!!! thanks heaps for all your help!
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
Imgburn getting stuck Burning DL Dvd+R
By Amzin in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2010, 16:33 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 11:17 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34
