IMGBurn DVD shell extension needs .NET framework 2.0 to run. If memory serves SVCD2DVD needs .NET 1.1 , correct? If so , how are you able to use both apps on one PC?
Reason I ask is since installing the ImgBurn ext tool (& .net 2.0), my install of S2D no longer functions. Tried doing a repair of it, but still no joy. Won't even start up to splashscreen.
.Net 1.1 and .Net 2 are able to coexist on a PC - no problem.
There may have been another change to your system. If you double click on the "SVCD2DVD demo.exe" file in the SVCD2DVD folder you can redo the registration process. This should solve the problem. If not let me know and we can try something else.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ahh...did not know that both flavors of .NET could reside at the same time. Sounds like that will solve it!
Thanks!
IMGBURN shell ext query
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 22nd Nov 2010, 10:21 -
IMGBURN shell ext - not working with Win 7 64bit?
By CBC in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 23rd Aug 2010, 18:11 -
S2D have its own settings when using imgburn ?
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 20th Aug 2009, 17:36 -
Help - Can't download .net Framework 2.0
By nhbfan12345 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Aug 2008, 15:30 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 10:05
