I just finished editing some home made audio tracks and named each
Track01 Track02...etc... through Track30 as I saved each in WAV format.
Total time was 60 mins and space used was 330mb. Burned at 32x using Nero 7.
When I play the new disc the tracks are all in the wrong order. It didnt burn
them in the order of the filenames which is how they need to be. I attempted
playback using Winamp and Mplayer but same order appears.
Any ideas why this happened or how to get the tracks to burn to disc in the right order?
Dave![]()
Try using the alphabet instead of numbers.
eg. track A, track B, etc.
Because you have 30 tracks and the alphabet is only 26 letters you will have to double up on some tracks. eg. track Aa, track Bb.
See if that works. -
I do like this and it works:
Artist Name or CD Title -01- Track Name
Artist Name or CD Title -02- Track Name
Artist Name or CD Title -03- Track Name
etc...
BTW
Nero SUCKSmoved to another forum, nobody likes me here... -
Let me make a guess...
You had these tracks:
- Track1
Track2
Track3
Track4
Track5
Track6
Track7
Track8
Track9
Track10
Track11
Track12
Track13
Track14
Track15
Track16
Track17
Track18
Track19
Track20
etc.
And it put them in this order:
- Track1
Track10
Track11
Track12
Track13
Track14
Track15
Track16
Track17
Track18
Track19
Track2
Track20
Track3
Track4
Track5
Track6
Track7
Track8
Track9
etc.
Then, that's a simple misunderstanding between human (intuitive) sorting and computer (literal) sorting.
Scott - Track1
Thanks for the fast replies.
Cornucopia...reason I number starting with 01 instead of 1 is I don't want the double digit single digit ordering problem to occur. That's not an issue but good suggestion.
I've done some more research here. It seems all of the tracks are in the right order EXCEPT the first and last. The numbering is in the right order too but song 30 is track 1 and song 1 is track 30.
I've also done a few more burn tests using an RW disc so I dont waste any more Rs. Interesting results. Looks like it has to do with how files are added to the project. I thought maybe it had to do with using CTRL-SHIFT to add all the files at once so I split it up. I used CTRL-SHIFT again....but this time instead of clicking 1 then 30 I clicked 1-16 and added...then 17 thru 30 and added. That burn it swapped track 1 for track 16.
I tried again holding CTRL only and selected each file one at a time starting with 1 then clicked ADD afterwards. That burn disc swapped Track 1 for 30 again.
I repeated the above add procedure again holding CTRL and selecting each track...but not to burn...just to observe how it added files to the project in the ADD line. Looks like everything stays in order but 1 ends up at the back of the line and 30 at the front. I copied this from the add line.
"Track30.wav" "Track02.wav" "Track03.wav" "Track04.wav" "Track05.wav" "Track06.wav" "Track07.wav" "Track08.wav" "Track09.wav" "Track10.wav" "Track11.wav" "Track12.wav" "Track13.wav" "Track14.wav" "Track15.wav" "Track16.wav" "Track17.wav" "Track18.wav" "Track19.wav" "Track20.wav" "Track21.wav" "Track22.wav" "Track23.wav" "Track24.wav" "Track25.wav" "Track26.wav" "Track27.wav" "Track28.wav" "Track29.wav" "Track01.wav"
I could start out selecting Track30 first then 2,3,4..etc...and 1 last. That should work since it reverses the first and last...1 will end up first and 30 last.
OK...last burn just finished. This time I added 1 track at a time and clicked ADD each time so there is only 1 file at a time in the ADD line. Lets see what we have here... YEP! Song 1 is Track 1 and 30 is 30. You have to add ONE file at a time and Click ADD each time to get it to work right. Must be a Nero thing!
Between this issue ...and Nerovision errors or Neroburn errors that have required me to re-install Nero7 2 times already.... plus Nero VCDs and Even a Nero MPG2 DVD having momentary freeze problems during playback....I tend to concur....that Nero is NOT the best way to go!
Is Roxio any better...or shoud I go with another 3rd party authoring software for Audio CD and DVDs? -
Windows has a shift-select bug that affects anything that uses the standard file load API. Try clicking on the second file in the list, hold down shift and click on the last file. Finally, hold down ctrl and click on the first file. Now click OK to load them. Now check the order.
Read my blog here.
I am using MY DVD that came with my drive and its EXCELLENT.
It got very nice setup for 2 drives. When I insert cd to read from and select files it automaticlly opens writable drive to put a disk in it
bizarre bug - DVD tracks playing in wrong order in DVP5990/92
By lhughes in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Aug 2010, 05:23 -
How to strip audio or subtitle tracks off a Blu-Ray Disc
By ppeterr in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Jul 2010, 14:45 -
How do you change the order of audio tracks?
By FallenAngelII in forum DVD RippingReplies: 0Last Post: 29th Mar 2010, 06:22 -
really screwy issue: PC will not read cdr-audio disc after it is burned
By mazinz in forum AudioReplies: 12Last Post: 1st Jul 2009, 00:38 -
*RESOLVED* resetting password on a networked HP printer? *RESOLVED*
By Xylob the Destroyer in forum ComputerReplies: 3Last Post: 21st Nov 2008, 14:50
