I have Nero V7 and Ulead Movie Factory 5. I have not done much copying at all. I have several DVD movies I recorded with my TV DVD recorder. (Presidian). I wanted to make copies and put 2 movies on 1 DVD. So I used Ulead to clip the movies from just the beginning to end, then used DVD shrink to shrink them to approx 2.2gb each. Then tried to use Nero V7 to copy them on 1 DVD. I used the copy multiple dvd's to 1 dvd in Nero 7. When the DVD was finished it finalized. I tried to play the DVD on my TV DVD players I have 2 and the DVD's dont have a menu and start playing the first movie with no selection available. Then when I stop it it locks up the player. How can I show the 2 different movies in the menu so each can be selected?
thank you
Don't use Nero for authoring.
Simplest tool for what you want to do is Tmpgenc DVD Author.
If you demux the two movies, GUIForDVDAuthor is a free alternative.Read my blog here.
I suppose there demuxed after DVD shrink. The audio and video files are in 2 different folders.
Thank you -
Shrink doesn't demux, it creates a new folder containing the DVD structure for the reduced movie. You have created two such folders, so you are staing with effectively two DVDs. Tmpgenc will allow you to import each of these using it's Add Video function. From there you can add menus etc.
Read my blog here.
Don't shrink each individual movie first, build the project then use DVD Shrink if needed.
Tmpgenc DVD Author will allow you to add the contents of each of your existing dvds. You will need to copy them to the harddrive first though. After you get them into Tmpgenc DVD Author (in 2 different tracks) using the "Add DVD VIdeo" create your desired selection menu then use the Output function to create the DVD Folders on the hdd of the project. Author might warn you that this project is larger than 1 DVD-R disk, but you can choose to "Ignore" this warning and the program will create the folders anyway. You can then import the folder (project) into DVD Shrink where the program will transcode (shrink) it to fit on 1 disk. If you have Nero Burning Rom installed, Shrink can also burn the DVD, if not then burn the shrunken VIDEO_TS and AUDIO_TS folders as you usually do.
Very easy after you do it a few times.
Good luck. -
Very good advice. I have several to do so by the time I get a few I should have it. I thank you
Making movies with chapters
By dw1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2008, 08:53 -
Making Movies is More difficult than I thought
By Alextaylor in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2008, 02:16 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making My Movies Into ISO File
By imdaman in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2007, 21:06 -
Nero 7 is making movies bigger than they should be...
By Harkonnen in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 02:59
