Am I right in thinking, no matter if I choose "no margin (keep aspect ratio)" or "fullscreen" in TMPGEnc settings- I will always have black borders on a 4:3 TV, given my source video was 16:9?
"No Margin (keep aspect ratio)" in TMGPEnc should enlarge the image so the height of the picture is the full height of the TV and crop the left and right edges.
Well, the source video in my case is actually 2.35:1
Never come across that one before, any settings I can use to eliminate the top and bottom borders? -
Use the Clip Frame function to trim 60 lines off the top and bottom of the frame. Continue to use "No Margin (keep aspect ratio)". Be sure to set the Source Aspect Ratio to 16:9 and the output Aspect Ratio to 4:3.
Be forewarned that you will be losing a large portion of the picture -- about 1/4 of the frame on both sides, ie, half the picture. -
I think you really need to explore this link:
http://www.widescreen.org/
Check it out!
Black borders all around video
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2010, 17:01 -
Adding borders WITHOUT resizing...
By creamsoda in forum EditingReplies: 14Last Post: 4th Jan 2010, 15:40 -
Cutting black borders
By HamishT in forum Authoring (DVD)Replies: 17Last Post: 4th Mar 2009, 17:53 -
Does anybody know how to convert 16:9 to 4:3 with black borders?
By tuanvn.2007 in forum Video ConversionReplies: 7Last Post: 20th Sep 2008, 02:13 -
Black Borders won't go away!!!
By mirandapanda in forum Newbie / General discussionsReplies: 6Last Post: 10th Sep 2008, 01:49
