Hi folks,
I have searched & searched but I did not find anything addressing my problem ... they are all dealing with AVI and DivX and so forth. Also, I was not sure where to post this ... so that is why I am here.
My Problem: I have bought a foreign dvd ... I think the way this dvd was done ... maybe they had copied the program from a Satelite ... since when I try to back up it the title comes up as "JVC recorder something".
Anyway, the movie plays fine until about 15 minutes into it ... and that's when you can clearly see that AUDIO is leading the VIDEO by about, I would guess, 2 or 3 seconds.
My Question:
Q1: What is the Easiest Way (assume a "Newbie") to fix this problem, preferrably using Freeware? Also, any Guides!!!
Q2: If no freeware, then what program do you recommend? Again my focus is on a program that basically does everything for you ... just click and go!?!?
Thanks,
G![/b]
No click and go tools.
Easiest, find and buy a better dvd source.
I would probably use vob2mpg to get one mpg, videoredo to cut it up where it starts to goes out of sync, try fix the sync with the builtin sync tool in videoredo (tools>Adjust Audio Synchronization), join back the mpgs and make a new dvd with tda.
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 15:35 -
Need to cut out 5 minutes of video from a dvd
By darkcyber in forum EditingReplies: 5Last Post: 2nd Nov 2010, 19:10 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 23:43 -
dvd editing leads to unacceptable results
By jamesgig in forum DVD RippingReplies: 7Last Post: 18th Sep 2008, 21:42 -
By jamesgig in forum DVD RippingReplies: 2Last Post: 7th Sep 2008, 01:49
