Hi,
I have problem with my DVD files burnt on DVD-RW. I recorded some TV programmes using DVD recorder then burnt DVD from that recorder. I used DVD-RW from imation encore white series (4.7GB).
To save space, I determined to convert those DVD files to VCD files. I used TSUNAMI MPEG DVD EasyPack Suite, Clone DVD & SONY DVD-ROM DDU1621 (configured as IDE slave) to do this. Conversion was successful. I could play back the VCD files.
As I have another PC (called it PC2) configured with LG4167B DVD drive & I had a lot of files to convert, I determined to speed up the process my doing conversion in both PCs. The problem came out as I found Windows explorer in PC2 couldn't read out file system of the DVD --- no VIDEO_RM, VIDEO_TS directories found, as if no DVD disc had been inserted into the drive. However, PowerDVD & NERO player softwares installed in PC2 could play all video files burnt on the disc.
I wonder why explorer in PC2 couldn't read the disc file system but applications there could read out the DVD's content ? No such problem found in the other PC with ONY DVD-ROM DDU1621 connected.
What should I do to correct this problem ?
Results 1 to 19 of 19
Maybe the folders are just 'hidden' and you don't have configured your 'PC2' explorer to show 'all files' (including system, read only...)
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Maybe you didn't close the DVD, IE Finalize it. Different PCs = different software installed = different capabilities.
No, explorer in the two PCs were configured to show all files/directories, including hidden & system.
TBoneit,
I don't understand what you mean by closing DVD & IE finalization. The DVD was burnt by DVD recorder. I just used Windows explorer to try read the DVD content.
I'd also tried to use CloneDVD & TSUNAMI MPEG DVD Easypack Launcher. Both of them couldn't read the DVD's content (i.e. they treated the DVD an empty DVD). -
Did you record in Video mode or VR mode? VR mode requires UDF software to read on a PC.
Maybe your dvd drive in PC 2 cannot read dvd-rw.
My dvd-rom (LG8120B) cannot read burned disc. -
Finalizing makes the DVD into a format that can be read on most drives. Until the disc is finalized you can go back and add content, after finalizing the recorder will create the proper structure so most drives can read it. Without finalizing in many cases only the recorder can read the disc.
OF course as was also suggested above if in VR mode that is another problem.
You say the software treated it as a empty disc? sounds like it needs finalizing. -
I didn't know what you mean. I used time recording. The recorder provided below options:Originally Posted by piano632
1. Source: TV channel;
2. Recording tO : HD or DVD, I choosed HD;
3. Quality: HQ, SP, SP+, LP, EP or SLP, I choosed SP;
4. Mode: Once, Daily, Weekly, etc, I choosed Once;
5. Date, start & end time of recording, title of result recorded programme (irrevalent);
6. PDC: I didn't make any change, it's OFF;
7. NICAM: I choosed CURRENT.
Also, the recorder allowed pressing one button to copy selected recorder programme to DVD disc on DVD drive.
Furthermore, as mentioned before, I had 2 PCs, one with old SONY DVD drive and one with suspected problematic LG DVD drive. Only the LG drive had this problem. I wonder if your mentioned UDF software could solve this problem.
Most recorders when you first format the disc, will give you the option of formatting in Video mode or VR mode. Video mode is the standard DVD format that all players use; VR mode allows editing and maybe some thumbnail images (but it isn't compatible with most players). If there's a chance it was recorded in VR mode, just install some sort of UDF reading software (such as Nero InCD, Roxio Drag-n-Drop, etc.) and see if it works then.
I could read directories & files from Windows Explorer in another PC configured with SONY DVD-ROM DDU1621. If finalizing was the reason, why inconsistent results found with SONY & LG DVD drives ? I said 'empty' because when I double clicked on DVD drive icon from PC2 Windows Explorer, nothing (subdirectories or files) appeared under DVD drive icon. Yet explorer didn't complained the DVD disc was unformatted. OopsOriginally Posted by TBoneit
I just re-read one DVD in my SONY drive, the label of the disc was DVD_VR with 2 directories named VIDEO_RM & VIDEO_TS. Did the label mean VR mode being used by DVD recorder ?
Sounds like VR mode is being used. This goes back to what I was trying to say by two computers being different even if they started out the same.
One could have some software installed that lets it read VR mode and the other computer doesn't that software and ability.
Good Luck -
Just ran Nero InfoTool 3.06 with below Disc information returned:Originally Posted by TBoneit
General
Type: DVD-RW
Capacity: 00:00:01 (0MB)
Extended Information
Tracks: n/a
Sessions: n/a
Blank Capacity: n/a
Manufacturer ID: CMCW03
Disc Status: Open, not finalized
Content
File System(s):
Title: n/a
Date: n/a
Publisher: n/a
Application: n/a
Obviously, this DVD disc was not finalized. But will the problem be solved after finalization ? What computer application could help me finalize the disc ? My DVD recorder didn't has any option setting about finalization.
PS: Everytime I burnt CD or DVD data disc, I didn't force finalizing the disc until NERO told me to do so because the content to burn on disc nearly fill up the disc. However, I didn't meet any problem reading these disc with the LG drive, why ?
Others information returned by Nero InfoTool
Nero InfoTool 3.06
Drive Information
Drive : HL-DT-ST DVDRAM GSA-4167B
Type : DVD-RAM Recorder
Firmware Version : DL13
Buffer Size : 2 MB
Date : ?
Serial Number : 03B8EB84B899
Vendor Specific :
Drive Letter : E:\
Mechanism : Tray
Read Speed : 8.0 , 2.4 X
Write Speed : 4.0 , 2.0 X
Read CD Text : Yes
Return C2 Pointers : Yes
Read CD-R : Yes
Read CD-RW : Yes
Read DVD-ROM : Yes
Read DVD-RAM : Yes
Read DVD-R : Yes
Read DVD-RW : Yes
Read DVD-R DL : Yes
Read DVD+R : Yes
Read DVD+RW : Yes
Read DVD+R DL : Yes
Read BD-ROM : No
Read BD-R : No
Read BD-RE : No
Read HD DVD-ROM : No
Read HD DVD-R : No
Read HD DVD-RW : No
Read HD-BURN : No
Read Digital Audio : Yes
Read CD+G : No
Read VideoCD : Yes
Write CD-R : Yes
Write CD-RW : Yes
Write DVD-R : Yes
Write DVD-RW : Yes
Write DVD-R DL : Yes
Write DVD+R : Yes
Write DVD+RW : Yes
Write DVD+R DL : Yes
Write DVD-RAM : Yes
Write BD-R : No
Write BD-RE : No
Write HD DVD-R : No
Write HD DVD-RW : No
Write HD-BURN-R : No
Write HD-BURN-RW : No
Buffer Underrun Protection : Yes
Mount Rainier : No
SolidBurn : No
Modes : Packet, TAO, DAO, SAO, RAW SAO, RAW DAO, RAW SAO 16, RAW SAO 96, RAW DAO 16, RAW DAO 96
Region Protection Control : RPC II
Region : None
Changes User : 5
Changes Vendor : 4
Disc Information (E:\)
Type : DVD-RW
Capacity : 00:00.01 (0 MB)
Tracks : 0
Sessions : 0
Interface Information
Adapter 1
Description : Primary IDE Channel
Driver
Description : system32\DRIVERS\atapi.sys
Company : Microsoft Corporation
Version : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
Description : IDE/ATAPI Port Driver
Attached Devices
Description : Master: IC35L060AVV207-0
Type : Disk Drive
DMA : On
Adapter 2
Description : Secondary IDE Channel
Driver
Attached Devices
Description : Master: HL-DT-ST DVDRAM GSA-4167B
Type : CD-Rom Drive
DMA : On
Autorun : On
Software Information
Operating System : Windows XP Professional (5.01.2600 Service Pack 2)
Country : Taiwan
Language : Chinese
ANSI Code Page : 950
OEM Code Page : 950
DirectX : DirectX 9.0c
Description : Nero Burning ROM
Version : 7, 0, 0, 0
Company : Nero AG
Version Check : Ok
Description : InCD
Version : 5, 0, 0, 0
Company : Nero AG
Description : Nero BurnRights Control Panel
Version : 1, 9, 0, 8
Company : Nero AG
Description : Nero CD - DVD Speed
Version : 4, 0, 7, 0
Company : Nero AG
Description : Nero DriveSpeed
Version : 3, 0, 2, 0
Company : Nero AG
Description : Cover Designer
Version : 2, 4, 0, 51
Company : Nero AG
Description : Nero BackItUp Application
Version : 2, 0, 0, 0
Company : Nero AG
Description : Nero Fast CD-Burning Plug-in
Company : Nero AG
Description : Nero Home
Version : 1, 0, 0, 0
Company : Nero AG
Description : Nero ImageDrive
Version : 3.0.0.1
Company : Nero AG
Description : Nero MediaHome
Version : 1, 4, 0, 7
Company : Ahead Software AG
Description : Nero PhotoSnap image editor
Version : 1, 2, 0, 6
Company : Nero AG
Description : Nero Recode 2
Version : 2, 2, 7, 2
Company : Nero AG
Description : Nero ShowTime
Version : 2, 1, 0, 4
Company : Nero AG
Description : Nero StartSmart
Version : 3, 0, 0, 0
Company : Nero AG
Description : Nero Wave Editor
Company : Nero AG
Description : Nero Library
Company : Nero AG
Description : NeroVision
Version : 4,0,0,1
Company : Nero AG
Description : Nero SoundTrax
Company : Nero AG
Description : PowerDVD
Version : 5.00.1307
Company : CyberLink Corp.
Hardware Information
CPU : Intel Pentium 4 CPU 2400 MHz
Bus Speed : 133 MHz
Motherboard : Gigabyte GA-8S655FX-L
System :
BIOS : Award F8
Memory : 512 MB
Sound : Realtek AC97 Audio
Video : Radeon 7000 / Radeon VE (Microsoft Corporation)
Driver Information
Driver : Abiosdsk
Description : n/a
Version : n/a
Company : n/a
Driver : abp480n5
Description : n/a
Version : n/a
Company : n/a
Driver : ACPI
Description : ACPI Driver for NT
Driver : ACPIEC
Description : ACPI Embedded Controller Driver
Version : 5.1.2600.0 (xpclient.010817-1148)
Driver : adpu160m
Description : n/a
Version : n/a
Company : n/a
Driver : aec
Description : Microsoft Acoustic Echo Canceller
Version : 5.1.2601.2180
Driver : Aha154x
Description : n/a
Version : n/a
Company : n/a
Driver : aic78u2
Description : n/a
Version : n/a
Company : n/a
Driver : aic78xx
Description : n/a
Version : n/a
Company : n/a
Driver : ALCXWDM
Description : Realtek AC'97 Audio Driver (WDM)
Version : 5.10.00.5940 built by: WinDDK
Company : Realtek Semiconductor Corp.
Driver : AliIde
Description : n/a
Version : n/a
Company : n/a
Driver : amsint
Description : n/a
Version : n/a
Company : n/a
Driver : Arp1394
Description : IP/1394 Arp Client
Driver : asc
Description : n/a
Version : n/a
Company : n/a
Driver : asc3350p
Description : n/a
Version : n/a
Company : n/a
Driver : asc3550
Description : n/a
Version : n/a
Company : n/a
Driver : AsyncMac
Description : MS Remote Access serial network driver
Driver : atapi
Driver : Atdisk
Description : n/a
Version : n/a
Company : n/a
Driver : ati2mtag
Description : ATI Radeon WindowsNT Miniport Driver
Version : 6.14.10.6462
Company : ATI Technologies Inc.
Driver : Atmarpc
Description : IP/ATM Arp Client
Driver : audstub
Description : AudStub Driver
Version : 5.1.2600.0 (XPClient.010817-1148)
Driver : awlegacy
Description : pcAnywhere Legacy Driver
Version : 9.2.1
Company : Symantec Corporation
Driver : AW_HOST
Description : n/a
Version : n/a
Company : n/a
Driver : cbidf2k
Description : CardBus/PCMCIA IDE Miniport Driver
Driver : CCDECODE
Description : WDM Closed Caption VBI Codec
Version : 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)
Driver : cd20xrnt
Description : n/a
Version : n/a
Company : n/a
Driver : Cdaudio
Description : CD-ROM Audio Filter Driver
Driver : Cdfs
Description : CD-ROM File System Driver
Driver : cdrbsdrv
Description : CD-ROM Filter Driver for Windows2000/xp
Version : 7. 0. 0. 5
Company : B.H.A Corporation
Driver : cdrbsvsd
Description : n/a
Version : n/a
Company : n/a
Driver : Cdrom
Description : SCSI CD-ROM Driver
Driver : Changer
Description : n/a
Version : n/a
Company : n/a
Driver : CmdIde
Description : n/a
Version : n/a
Company : n/a
Driver : Cpqarray
Description : n/a
Version : n/a
Company : n/a
Driver : dac960nt
Description : n/a
Version : n/a
Company : n/a
Driver : Disk
Description : PnP Disk Driver
Driver : dmboot
Description : NT Disk Manager Startup Driver
Version : 2600.2180.503.0
Company : Microsoft Corp., Veritas Software
Driver : dmio
Description : NT Disk Manager I/O Driver
Driver : dmload
Version : 2600.0.503.0
Company : Microsoft Corp., Veritas Software.
Driver : DMusic
Description : Microsoft Kernel DLS Synthesizer
Driver : dpti2o
Description : n/a
Version : n/a
Company : n/a
Driver : drmkaud
Description : Microsoft Kernel DRM Audio Descrambler Filter
Driver : eeCtrl
Description : n/a
Version : n/a
Company : n/a
Driver : EraserUtilRebootDrv
Description : n/a
Version : n/a
Company : n/a
Driver : Fastfat
Description : Fast FAT File System Driver
Driver : Fdc
Description : Floppy Disk Controller Driver
Driver : Flpydisk
Description : Floppy Driver
Driver : FltMgr
Description : Microsoft Filesystem Filter Manager
Version : 5.1.2600.2978 (xpsp_sp2_gdr.060821-0039)
Driver : FsVga
Description : Full Screen Video Driver
Driver : Ftdisk
Description : FT Disk Driver
Driver : gameenum
Description : Game Port Enumerator
Driver : Gernuwa
Description : pcAnywhere AWUNREG Driver
Version : 10.5.0
Driver : Gpc
Description : n/a
Version : n/a
Company : n/a
Driver : hpn
Description : n/a
Version : n/a
Company : n/a
Driver : HTTP
Description : HTTP Protocol Stack
Version : 5.1.2600.2869 (xpsp_sp2_gdr.060316-1512)
Driver : i2omgmt
Description : n/a
Version : n/a
Company : n/a
Driver : i2omp
Description : n/a
Version : n/a
Company : n/a
Driver : i8042prt
Description : i8042 Port Driver
Driver : Imapi
Description : IMAPI Kernel Driver
Driver : InCDfs
Description : InCD File System Driver
Company : Nero AG
Driver : InCDPass
Description : Ahead RW Filter Driver
Company : Nero AG
Driver : incdrm
Description : Ahead MRW Filter Driver
Company : Nero AG
Driver : ini910u
Description : n/a
Version : n/a
Company : n/a
Driver : IntelIde
Description : n/a
Version : n/a
Company : n/a
Driver : intelppm
Description : Processor Device Driver
Driver : Ip6Fw
Description : IPv6 Windows Firewall Driver
Driver : IpFilterDriver
Description : n/a
Version : n/a
Company : n/a
Driver : IpInIp
Description : IP in IP Encapsulation Driver
Driver : IpNat
Description : IP Network Address Translator
Version : 5.1.2600.2524 (xpsp_sp2_gdr.040919-1056)
Driver : IPSec
Description : IPSec Driver
Driver : IRENUM
Description : Infra-Red Bus Enumerator
Driver : isapnp
Description : PNP ISA Bus Driver
Driver : kmixer
Description : Kernel Mode Audio Mixer
Version : 5.1.2600.2929 (xpsp_sp2_gdr.060613-2359)
Driver : lbrtfdc
Description : n/a
Version : n/a
Company : n/a
Driver : Modem
Description : Modem Device Driver
Driver : mraid35x
Description : n/a
Version : n/a
Company : n/a
Driver : MRxDAV
Description : Windows NT WebDav Minirdr
Driver : MSKSSRV
Description : MS KS Server
Driver : MSPCLOCK
Description : MS Proxy Clock
Driver : MSPQM
Description : MS Proxy Quality Manager
Driver : mssmbios
Description : System Management BIOS Driver
Driver : MSTEE
Description : WDM Tee/Communication Transform Filter
Driver : NABTSFEC
Description : WDM NABTS/FEC VBI Codec
Driver : NAVENG
Description : n/a
Version : n/a
Company : n/a
Driver : NAVEX15
Description : n/a
Version : n/a
Company : n/a
Driver : NdisIP
Description : Microsoft IP Driver
Driver : NdisTapi
Description : NDIS 3.0 connection wrapper driver
Driver : Ndisuio
Description : NDIS User mode I/O Driver
Driver : NdisWan
Description : MS PPP Framing Driver (Strong Encryption)
Driver : NIC1394
Description : IEEE1394 Ndis Miniport and Call Manager
Driver : Npfs
Description : NPFS Driver
Driver : Ntfs
Description : NT File System Driver
Driver : NwlnkFlt
Description : NWLINK2 Traffic Filter Driver
Driver : NwlnkFwd
Description : NWLINK2 Forwarder Driver
Driver : ohci1394
Description : 1394 OpenHCI Port Driver
Driver : Parport
Description : Parallel Port Driver
Driver : PartMgr
Description : Partition Manager
Driver : ParVdm
Description : VDM Parallel Driver
Driver : PCI
Description : NT Plug and Play PCI Enumerator
Driver : PCIDump
Description : n/a
Version : n/a
Company : n/a
Driver : PCIIde
Description : Generic PCI IDE Bus Driver
Driver : Pcmcia
Description : PCMCIA Bus Driver
Driver : Pcouffin
Description : Patin-Couffin low level access layer for CD devices
Version : 1.28
Company : VSO Software
Driver : PDCOMP
Description : n/a
Version : n/a
Company : n/a
Driver : PDFRAME
Description : n/a
Version : n/a
Company : n/a
Driver : PDRELI
Description : n/a
Version : n/a
Company : n/a
Driver : PDRFRAME
Description : n/a
Version : n/a
Company : n/a
Driver : perc2
Description : n/a
Version : n/a
Company : n/a
Driver : perc2hib
Description : n/a
Version : n/a
Company : n/a
Driver : pfc
Description : Padus(R) ASPI Shell
Version : 2, 5, 0, 204
Company : Padus, Inc.
Driver : PptpMiniport
Description : n/a
Version : n/a
Company : n/a
Driver : PSched
Description : MS QoS Packet Scheduler
Driver : Ptilink
Description : Parallel Technologies DirectParallel IO Library
Version : 1.10 (XPClient.010817-1148)
Company : Parallel Technologies, Inc.
Driver : PxHelp20
Description : Px Engine Device Driver for Windows 2000/XP
Version : 2.03.12a
Company : Sonic Solutions
Driver : ql1080
Description : n/a
Version : n/a
Company : n/a
Driver : Ql10wnt
Description : n/a
Version : n/a
Company : n/a
Driver : ql12160
Description : n/a
Version : n/a
Company : n/a
Driver : ql1240
Description : n/a
Version : n/a
Company : n/a
Driver : ql1280
Description : n/a
Version : n/a
Company : n/a
Driver : Rasl2tp
Description : RAS L2TP mini-port/call-manager driver
Driver : RasPppoe
Description : RAS PPPoE mini-port/call-manager driver
Driver : Raspti
Description : PTI DirectParallel(R) mini-port/call-manager driver
Driver : Rdbss
Description : Redirected Drive Buffering SubSystem Driver
Version : 5.1.2600.2902 (xpsp_sp2_gdr.060505-0036)
Driver : RDPCDD
Description : RDP Miniport
Driver : rdpdr
Description : Microsoft RDP Device redirector
Driver : RDPWD
Description : RDP Terminal Stack Driver (US/Canada Only, Not for Export)
Version : 5.1.2600.2695 (xpsp_sp2_gdr.050609-1528)
Driver : redbook
Description : Redbook Audio Filter Driver
Driver : rtl8139
Description : Realtek RTL8139 NDIS 5.0 Driver
Version : 5.398.613.2003 built by: WinDDK
Company : Realtek Semiconductor Corporation
Driver : SAVRT
Description : n/a
Version : n/a
Company : n/a
Driver : SAVRTPEL
Description : n/a
Version : n/a
Company : n/a
Driver : SCDEmu
Description : PowerISO Virtual Drive
Version : 2, 9, 0, 0
Company : PowerISO Computing, Inc.
Driver : Secdrv
Description : n/a
Version : n/a
Company : n/a
Driver : serenum
Description : Serial Port Enumerator
Driver : Serial
Description : Serial Device Driver
Driver : Sfloppy
Description : SCSI Floppy Driver
Driver : Simbad
Description : n/a
Version : n/a
Company : n/a
Driver : SLIP
Description : Microsoft Slip Deframing Filter Minidriver
Driver : SNPSTD3
Description : PC Camera driver
Version : 1, 2, 1, 1
Company : N/A
Driver : SONYPVU1
Description : Sony USB Lower Filter driver
Version : 1.3.0526.0 (XPClient.010817-1148)
Company : Sony Corporation
Driver : Sparrow
Description : n/a
Version : n/a
Company : n/a
Driver : SPBBCDrv
Description : n/a
Version : n/a
Company : n/a
Driver : splitter
Description : Microsoft Kernel Audio Splitter
Driver : sr
Description : System Restore Filesystem Filter Driver
Driver : Srv
Description : Server driver
Version : 5.1.2600.2893 (xpsp_sp2_gdr.060420-2102)
Driver : streamip
Description : Microsoft IP Test Driver
Driver : STV680
Description : ST-VIBU STV680 Camera Driver (WDM Main Driver)
Version : 1-12
Company : STMicroelectronics
Driver : swenum
Description : Plug and Play Software Device Enumerator
Driver : swmidi
Description : Microsoft GS Wavetable Synthesizer
Driver : symc810
Description : n/a
Version : n/a
Company : n/a
Driver : symc8xx
Description : n/a
Version : n/a
Company : n/a
Driver : SymEvent
Description : Symantec Event Library
Version : 12.0.3.1
Driver : sym_hi
Description : n/a
Version : n/a
Company : n/a
Driver : sym_u3
Description : n/a
Version : n/a
Company : n/a
Driver : sysaudio
Description : System Audio WDM Filter
Driver : Tcpip
Description : TCP/IP Protocol Driver
Version : 5.1.2600.2892 (xpsp_sp2_gdr.060420-0254)
Driver : TDPIPE
Description : Named Pipe Transport Driver
Driver : TDTCP
Description : TCP Transport Driver
Driver : TermDD
Description : Terminal Server Driver
Driver : TosIde
Description : n/a
Version : n/a
Company : n/a
Driver : uagp35
Description : MS AGPv3.5 Filter
Driver : Udfs
Description : UDF File System Driver
Driver : ultra
Description : n/a
Version : n/a
Company : n/a
Driver : Update
Description : Update Driver
Ver -
You need to finalize in the recorder. Have you looked in the manual for the DVD recorder for finalize or tried calling technical support?
Yes I'd read through the whole DVD recorder manual, it said nothing about how to finalize DVD disc burnt.Originally Posted by TBoneit
The "Setup Menu - Recording" of my DVD recorder has below settings:
Current setting marked with '*'
1. Auto Chap Mark: 5min./10min./20min./30min./Off*
2. Record Quality: HQ/SP*/SP+/LP/SLP
3. APS: SCAN*
4. Modify Channel: EDIT* (allows change of Program Number, Channel
Name, Standard e.g. 5. PAL,NTSC & other TV channel settings)
6. Program Table: SORT* (list all scanned TV channels for sorting in
order)
7. Timer Setting Menu: OK* (Pressing OK switched to Timer Recording
setup menu)
8. Contry Selection:
No setting seemed relevant.
Usually I recorded TV programmes to HDD of the DVD recorder. To copy HDD content to DVD disc, I need two steps:
1. Select files to add to disc from list via remote control;
2. Press Dub button on remote control to start DVD burning.
Throughout the process, recorder didn't prompt me to do any finalization on the disc.
Actually, the recorder allowed direct recording to DVD. So I changed the setting and repeated the recording process. As expected, the burnt disc was not finalized.
I tried reporting case to DVD recorder vendor via the web site. For unknown reason, I couldn't sent them message via their provide message board page http://www.soman.net/CASE/JK/en/book_write.asp.
Besides, I also reported case to LG local dealer via e-mail. I'm still waiting for their reply.
Well good luck. There were some messages about reading open discs here. Looks like you'll have to search here and on the web.
The problem with an open disc is you may be able to read it in your recorder as I can in my Pioneer. However if others want to watch it elsewhere they are usually out of luck so you couldn't send a family movie on disc even and what do you do when your recorder dies? -
When I finish reecording anything on either of my two recorders it will ask whether I want to Finalize or not. If I plan to add another session to the same disk I chose no. If I want to take it upstairs to my TV DVD player I choose yes.
Enven burning programs have that finalizing feature. In Nero Burning Rom, if you choose Multi session, it wil not finalize. If you don't it will.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Bingo! I found the finalize option from the indistinct DVD recorder menu. I finalized the DVD from there. When I put the finalized DVD disc to LG DVD drive, Window XP explorer could finally read its directory tree and all files (e.g. .VOB) underneath.Originally Posted by TBoneit
Tks for help
Glad to hear you solved your problem. Don't you just love it when every needed function is clearly marked, easy to find and intuitive in operation.
My limited understanding is that when you finalize a DVD it creates the directory structure so Windows and DVD players can find the files. A DVD recorder knows where it puts the files on a unfinalized disc and can find them so when you use the recorder it can play the disc.
How Extensive Is Windows System Restore(XP Pro)?
By hech54 in forum ComputerReplies: 10Last Post: 11th Aug 2010, 23:55 -
Windows CE Operateing System
By vsopwk in forum ComputerReplies: 4Last Post: 16th Apr 2009, 23:50 -
'vlc' playing dvd copied to file system
By canellas in forum LinuxReplies: 6Last Post: 2nd Jan 2008, 05:02 -
Pioneer DVR112d maybe faulty won't read dvdrs and makes system crash!!
By rockonvidtrade in forum DVD & Blu-ray WritersReplies: 12Last Post: 9th Jun 2007, 03:44 -
File system for a DVD recorder HD
By csanders1962 in forum ComputerReplies: 1Last Post: 30th May 2007, 15:08
