Picked up a Cyberhome 300s, mfg. date Nov.2003 [Setup shows 300s.20.03]
The unit works without any problems using a commercial disk. A disk burned in my il0 RHD04, RO4 or Lighton 5045 the will not play. This is for a –R/RW or +R/RW
I do not use the ilo’s or Lighton for play.
I am using two Cyberhome 1600 for this and do not have any problems These things will play almost anything. The 300s was for an RV..
Commercial disk OK,.When a burned disk is used the unit will display a menu.
On top is -- Disk, -choices right below are Video, Video_RM , Video_TS
Below that are Display and Playmode
Selections can be made but are not permanent and I can not get any further than the menu
The Unit Does Not Lock Up
I have looked through a downloaded Manual and have not seen an answer here or in the fourms Hopefully I am not doing what the unit wants and do not see it.
Results 1 to 1 of 1
Need help finding replacement for Cyberhome player
By canofhumdingers in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Mar 2012, 20:15 -
Advice about Detailer / Proc Amp for VHS source, Vidimate VDM-300S
By jrodefeld in forum RestorationReplies: 5Last Post: 29th Jun 2011, 21:34 -
CyberHome DVD Recorder
By JRPAT in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Sep 2008, 18:08 -
Cyberhome DVR1600ME2 firmware
By DogDoor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Jun 2008, 15:45 -
cyberhome 300s need a firmware update
By etrin in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Dec 2007, 06:12
