hey
Recently I've Noticed I Rarely Get Succesfully Burned Discs
1 Every 5 DVD-Rs
I'm Thinkin It Could Be The Media?
Ridisc Full-Face Printable (8x) DVD-R ?
The Software?
Nero 7 & Sometimes Alcohol 120%
Or It Can Be My DVD Recorder?
Pioneer DVR-109
Which I Bought On Release Date 6 January, 2005
What Do You Guys Think?
Thanx
rhem,
You could try Taiyo Yuden disks, and/or using ImgBurn for the burning as a partial test to see if it's the burner, or you could post a burn log from Nero. The cheapest, most likely way to find the problem is to post the Nero burn log, preferably from a burn that failed. -
The first thing to change is always the DVD media. It's the cheapest and easiest to modify. Try some different media. You can check your burner in 'DVD Writers' to the left and see what others use for media. If you try several different brands with the same results, try cleaning the laser lens. Next try a firmware upgrade, though they are usually for working with newer media and that is likely not your problem.
Out of maybe 500 or more burns with different burners, I have probably had one or two coasters and both of them were my fault and not the media or burner. You should have no failures. I use TY media now and I used ProDisk in the past. The TY was not really much higher priced and works well for me.
If you have failures with quality media that is compatible with your burner and your software is not at fault, maybe the burner is failing. Even the best burners can have manufacturer flaws. But I would try a media change and the other ideas before considering replacement.
Okay I'll Post Up A burn log from Nero soon. and i 've got leatest firmware. and i'll also try cleanin it
thanx
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 02:01 -
DVD Burner
By jason in forum Newbie / General discussionsReplies: 8Last Post: 15th Feb 2008, 16:02 -
What is the best all around DVD/CD Burner?
By uncleB in forum DVD & Blu-ray WritersReplies: 30Last Post: 14th Dec 2007, 05:01 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
burner not seeing dvd
By SiberSan in forum ComputerReplies: 1Last Post: 1st Oct 2007, 13:46
