Hi Everyone,
I convert a WMV to MPEG with WINAVI-7 but when i want to cut some parts from the video with virtualdub i choose to compress it with DIVX6 or Xvid/MPEG4 but i found that thera is a delay of 1s b/n the soundtrack and the video, How can i fix it?
are you editing the mpg? or wmv but virtualdub doesn't support wmv...
WMV often uses variable bitrate audio. This can cause sync problems when converted. It may also have VBR video. If you are able to convert the audio to constant bitrate audio, that may help to fix the sync problems. Unfortunately, not a lot of non-MS programs handle WMV very well. You could drop it into WMM and maybe save it out as DV, then do your conversions to Xvid. WinAVI has more problems than solutions, so I won't use it for much of anything.
I convert it to MPEG with no problems then i edit it with Virtualdub, but the result is an AVI file with Sync problems, can i just save the "cut edition" in MPEG form with virtualdub??
mpeg is not a format meant for editing. Why not edit your WMV in Windows Movie Maker first, output as DV avi, then convert ?
Read my blog here.
New to editing with VirtualDub
By xNesX in forum EditingReplies: 2Last Post: 18th May 2011, 23:56 -
Editing FLV in VirtualDub
By CursedLemon in forum EditingReplies: 12Last Post: 29th Jul 2010, 23:02 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 20:19 -
Virtualdub, editing out faces?
By capman21 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Mar 2009, 21:12 -
mp3 editing with VirtualDub
By tomchook in forum AudioReplies: 2Last Post: 2nd Jul 2008, 11:48
