i am looking for the best way to save my VHS' on DVD.
Is the quality better if the tape and dvd-recorder are one unit(should have HDD included)?
Or does a connection with a simple cable work just as well.
I was looking into stuff like the Pioneer DVR-RT602H-S, or is it cheaper just to buy a vhs-player and a good dvd-recorder?
Good VCR, good DVD recorder, separate units.
The BEST quality will be with separate units, preferably a decent capture card or a DV converter, to get the video to your computer where you can tweak it to improve the quality. Many tapes I see have TONS of noise and are VERY faded. While a DVD recorder can improve the noise a bit, they don't correct for color problems.
You MUST have a decent VCR too!
VHS to DVD units with menu capability.
By meneedit in forum Video ConversionReplies: 5Last Post: 9th Feb 2012, 08:17 -
How can I rip DVD to AVI and make each chapter a seperate file
By mikeyshine in forum DVD RippingReplies: 10Last Post: 23rd Sep 2011, 15:02 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 13:37 -
DV AVI to WAV problem, exports in Units? then no dvd SYNC
By mrmoodswing in forum Capturing and VCRReplies: 0Last Post: 20th Jul 2008, 17:35 -
Do you use a switch box to add units to your tv/entertainment center?
By yoda313 in forum PollsReplies: 24Last Post: 6th Dec 2007, 07:14
