Could someone explain to a newbie the particulars of "flashing firmware"? Specifically, I have a Pioneer 111D with riplock, and I understand that the riplock can be flashed away. But this is another language to me. What does this process mean, and where would I find out the specifics for doing this for my particular drive?
Another term often used is hacked firmware. A firmware is a communication between the hardware (dvd writer) and the PC. more info here:
http://en.wikipedia.org/wiki/Firmware
Many manufacturers lock the read speed for ripping a DVD, mainly at 2X. When you flash your drive with a hacked formware, you remove that rippng speed restriction. A hacked firmware will also remove any region code restrictions making your dvd burner region free.
But be careful, using a hacked firmware will in all cases invalidate the warranty of the drive. -
I tried using a region-free rip-speed-unlock firmware for my Pioneer DVR-109 and it couldn't write a DVD or CD without loads of errors. I'd stick to Pioneer genuine firmwares if possible.
Firmware basically tells your DVD writer how to behave, and how to talk to the rest of your computer. It's important that you are careful when changing it.
I/O light flashing..help..need to connect HT to comp.
By techspark in forum Media Center PC / MediaCentersReplies: 7Last Post: 2nd Mar 2011, 12:30 -
Flashing went wrong with my DVP5992/37
By chiquito3 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 2nd Apr 2010, 19:56 -
Native Linux firmware flashing
By disturbed1 in forum LinuxReplies: 0Last Post: 7th Mar 2009, 21:09 -
Flashing Arrows To Emphasise
By Squid_uk in forum EditingReplies: 10Last Post: 13th Mar 2008, 22:17 -
VirtualDub - Flashing lines on playback
By terrypin in forum Newbie / General discussionsReplies: 9Last Post: 28th Aug 2007, 04:27
