  1. I am looking at purchasing this unit since I really do not need the 160gb or 250gb versions of this model. Does anyone have this? If so, what are your opinions?
  2. Preservationist davideck's Avatar
    Feb 2003
    USA
    I am very satisfied with my RD-KX50. As I see it;
    Pros;
    Outstanding Picture quality.
    Excellent TBC performance for analog tape sources.
    1394 Input with Auto chapter detect.
    HDMI Output.
    Great Timeslip functionality.
    Instant Skip / Instant Replay buttons - I wish that all of my DVD players had these.
    Extensive editing and authoring capabilities.
    Easy Record Menu (No TV Guide).
    Low Standy power consumption.
    Cons;
    IRE Error
    Life is better when you focus on the signals instead of the noise.
  3. Could you elaborate on the ire error? Too light? Too dark? Can a simple color corrector fix it?
  4. Preservationist davideck's Avatar
    Feb 2003
    USA
    The DVDs that it makes tend to look a bit brighter in other players. There is a record mode select meant to compensate for this, but it has not been a major issue for me. I mentioned it because others have mentioned it. Other manufacturers seem to have similar issues as well.
    https://forum.videohelp.com/viewtopic.php?p=1520709#1520709
  5. I had not realized that gshelley61 had posted results about the IRE error in these recorders. I independently tested the Sony GX315 and JVC DR-M10S on this thread and found that they behave just as he described,
    https://forum.videohelp.com/viewtopic.php?t=279460
    I now have a second JVC DR-M10S to test.
