hey , i take a avi file, convert it with convertxtodvd then burn it with nero and sometimes it skips while playing on standalone dvd player and other times it burns perfect and plays great help me out pelase
thansk alot guys
The most common cause of that problem is the media used and less often the player. First try some different brand of media or try the disc on different players to rule out the media. It's easiest to change the brand of a DVD than anything else. If you look to the left under 'DVD Writers' and 'DVD Players' for your burner and player, you can see what others use and suggest. You can also look up your present media in 'DVD Media'.
From there, check the file on the computer after ConvertXToDVD finishes it, before you burn it. If it's alright, then you may have narrowed down the problem. Do other programs like DVD Shrink cause the same problem?
Next the burner. But you would have the problem with most all files if the burner was at fault.
You have to be systematic about it and eliminate all the things that aren't causing it before you figure out what is causing it.
And welcome to our forums.
awesome thanks alot for the help , that makes total sense , this site is awesome it has taught me basically everything i know about this stuff thansk again
Title skip in MultiAVCHD
By maniachiavelli in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jun 2012, 22:29 -
Commercial Skip
By Montani304 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2011, 08:54 -
how to skip main menu
By arumugam49 in forum Authoring (DVD)Replies: 3Last Post: 24th Oct 2010, 09:08 -
How to skip unselecting pictures?
By coody in forum ComputerReplies: 1Last Post: 9th Mar 2009, 11:08 -
MKV-Skip Scenes
By jah711 in forum Blu-ray RippingReplies: 0Last Post: 5th Aug 2008, 19:10
