    Jun 2006
    I ahve nero 6 enterprise edition. my problem is on my computer at work i can convert avi files to mpeg dvd files and burn the files onto my dvd. Here though i convert files open up nero enterprise edition and i slect make my own dvd then i choose add file it goes real quick and i cannot proceed ? any idea why ? Also i have nero 7 and when i winrar it it makes it a bin and cue file. what software is out there that someone can recomend i use to convert the files to a exe ? Thanks for any help. mac
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    bin/cue files are typically disc images. Load into a burning app and burn to cd/dvd.
    Google is your Friend
    Jun 2006
    Planet Earth
    Use virtual Daemon Manager to load you Cue file in virtual CD/DVD-ROM to avoid burn it to media (CD/DVD). Or get one of the tool here : https://www.videohelp.com/tools?s=31#31 .
    You (Nero) may not have the codec to process the file. Can you play it? Other thing maybe that the file is corrupted. Some program like TMPGenc and Premiere check the file for conformity and refuse to load it if it does not conform 100% to spec eventhough WMP/MPC can play it. Use on of these to try to fix it (depend on codecs) : https://www.videohelp.com/tools?s=12#12 . Be cautious and work with your backup to avoid damage to your original file.
