HI..
have a little problem that confuses me a lot..
I'm converting some AVI files into dvds using Mainconcept MPEG Encoder,I'm using the best sittings in it,but I'm getting a dvd movie that isn't the same quality as the source file.
it's so bright and have some kind of little blush in it..
I've heared that Mainconcept MPEG Encoder is the best AVI to DVD converter,so have I been misinformed or there's something in the sittings for the coloures...
THANKS IN ADVANCE...
AND SORRY FOR MY WEAK ENGLISH.
What are "The Best Settings" ?
Are you configuring bitrate etc manually, or using a pre-set ?
What is your source ?
If it is compressed avi (Xvid/Divx) then you have to set your sights realistically. These videos are heavily compressed, and contain a lot of flaws. Many of these do not show up on your PC monitor, but will show up on a TV set. This is in part because of the different calibration of the devices, and in part because of this different circuitry involved. regardless, they are not the same. Avi to DVD conversion usually also require resizing of the source, either in both directions, or at least in one direction to address pixel aspect ratio differences. This increases the effects of the flaws.
You can mitigate some of these issues to a degree by using filters in virtualdub or avisynth, then frameserving these to your encoder. However you will not clean them all up, and you will not get DVD quality results.
If you don't believe your source is flawed - and many people do believe that their avi files are image perfect - open the avi in VLC, and turn the gamma up a few notches to better match a TV's output. Then look at motion areas, and also at areas with a small tonal range and no pattern - walls, sky etc. Look at the shimmers and shifting of colours and blocks from the compression.
In short
Step 1 : Filter
Step 2 : Correct encoder settings
Step 3 : Acceptance that the results will always be affected
Step 4 : Go and buy a standalone Divx certified player as the results will be as good if not better than your encoded results, but with less work and a lot more clips to a discRead my blog here.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 19:06
