Hi,
I am using:
Panasonic DMRES10 DVD Recorder
NEC N4750A DVD Writer on PC (latest firmware v1.03)
Panasonic 3x DVD-RAM Media
I've read on these forums how it is possible to copy and edit the VRO file that the Panasonic creates on the DVD-Ram. However when I try the resultant file is corrupted. When displayed it contains horizontal bars of video from other scenes.
I have tried the following, all of which I have seen recommended for VRO files on this forum, without success:
reading the VRO file from the disc and copying it to the hard drive
renaming the VRO file to a .mpg file
running the file through ProjectX - a 45 min program gave 27,271 errors
editing the resultant m2v file in MPEG2Schnitt - it caused the program to crash
opening the file in Womble MPEG Editor, DGMPEGDecoder, Canopus ProCoder & TMPEGEnc DVD Author.
It looks to me as if it could be either a copy protection feature kicking in or an incompatibility in the NEC DVD Writer. I have seen one report that the user could not edit using Panasonic media as it included "protection" but others seem to have used it successfully.
When scrolling through the VRO file using DGMPEGDecoder you can see that the horizontal bars are always the same pattern but the content changes depending on whether you are scrolling forward or backward. They appear to come from a previous scene rather than an adjacent frame.
The source is a UK DTT broadcast recorded on a Humax PVR9200T and recorded to DVD via Scart.
Help!
Results 1 to 10 of 10
Richard
If you can do a capture (Womble MPEG2VCR has this feature) and post it, you may get some help. I was seeing problems with panasonic recordings, and LS and GShelly came through for me. Changed some settings in the Panasonics (have 2 of them) and haven't seen it since (vertical bars in half the video).
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Thanks for the tip. I've uploaded a few grabs here:
http://www.zen78481.zen.co.uk/vro.htm
BTW I was wrong when I said that the content of the interference changed depending on whether I scrolled forward or backward.
Any help would be much appreciated, even if it is just an educated guess as to whether replacing the media or the PC writer would be the best bet.
Thanks.Richard -
does it happen with all recordings on? or just one?
It happens with all recordings made to RAM discs. I can transfer stuff by using DVD-RW media but it is tedious having to finalize the discs on the Panasonic, then rip them on the PC.
Sorry for starting a duplicate thread - I thought I might have started this in the wrong forum.Richard -
Hi
I have been editing vids from my Panasonic DVD Recorder (DMRE95H) for over two years without any problems.
I bought Panasonic as I wanted to use the DVD-RAM method of transfer.
I did initially have some problems and had to change one of the settings on the DVD Recorder.
I have downloaded your manual and I can't see that you have the Hybrid VBR option, I know it appears to have been removed from the next generations of DVD Recorder after mine.
To edit. I simple:-
1. Copy VRO file off DVD-RAM disc to hard drive.
2. Edit in either Womble MPEG-VCR, Womble Video Wizard or VideoRedo.
3. Save the edited video.
I have never had any problems with this method.
One question, have you edited the video at all on the Panasonic DVD Recorder? -
You may ask in the projectx forum: http://forum.dvbtechnics.info/forumdisplay.php?f=16running the file through ProjectX - a 45 min program gave 27,271 errors
It's a German forum, but you can post questions in English too.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I haven't edited the video on the Panasonic at all. It's just a straight recording. I've done it at both SP and LP but the result is the same.Originally Posted by Hal_loe
Did you use Panasonic media?Richard -
Yes, always use Panasonic DVD-RAM discs. I am currently using the non-cartridge 3x speed discs.Originally Posted by Dr_Calculus
Main difference is my recorder has a hard drive. So I record to the hard drive first and then transfer to the DVD-RAM disc.
This shouldn't make any difference though as the transfers to DVD-RAM are done at high speed. Where as normal recordings are done at a much lower speed.
Do normal analogue tv recordings work ok?
Not sure what else to suggest. -
I've solved the problem. The NEC DVD-RW drive started screwing up when writing ordinary DVDs so I sent it back and the replacement I've received today works fine with DVD-RAM.
Thanks to everyone for their help.Richard
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 08:06 -
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 16:30 -
Editing/converting VRO files
By mariqueri in forum Video ConversionReplies: 28Last Post: 20th May 2009, 12:25 -
RAM .vro files to usable format?
By nelsh in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 19:05 -
Extracting .VRO file from DVD-RAM to pc for editing
By mattsz in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2007, 13:25
