Results 1 to 17 of 17
  1. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Hello everyone!
    I was just wonder how can I make my backups from a DVD to a 700 mb CD?
    Personnaly I would like that every DVD players could read the disc. But if that is not possible, than I would like to pass them just to Divx (my DVD Recorder reads everything).
    Thaks in advance.
    EDIT --» BTW, I would like to use some simple program, because i don't really know how to work with complex programs such like AutoGK, etc.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    You think AutoGK is complex? You only need 3 or 4 mouse clicks and you're laughing. Check the guides section, there's umpteen DVD to AVI guides.
    He's a liar and a murderer, and I say that with all due respect.
  3. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Hi,
    thanks for your fast response.
    I've tried AutoGK and it is pretty simple to use, and it works perfectly, but tell me, how much time do I need to wait until the movie is ready? The movie has a duration of 45 min.
    I have just tried a little bit, but what I've seen is great.
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Mostly depends on your CPU speed, you haven't listed yours so I can't answer.
  5. Member PTsniper's Avatar
    Aug 2006
    Portugal
    where can i see that?
  6. Member steveryan's Avatar
    Jan 2003
    Manchester
    Start/control panel/system the info will be displayed.
  7. Member PTsniper's Avatar
    Aug 2006
    Portugal
    It's in portuguese, but I think you can understand it.
    I hope it's this what you talking about.
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You should be encoding at real-time or better, so 45 minutes of video should take 45 minutes or less.
    If you want every DVD player to read it you could look at VCD, although most movies would require at least 2 discs, and the quality would be crap.
    Basically, if you want DVD backups to play in DVD players, use DVDs. The price difference between DVD and CD is very small, and disappears altogether if you burn 5 - 6 movies toa DVD after conversion.
    Read my blog here.
  9. Member PTsniper's Avatar
    Aug 2006
    Portugal
    but I'm not enconding a movie, it's an episode of a portuguese serie and has a duration of 45 min, that why I dind't whant to burn a DVD with a single episode.
  10. Member steveryan's Avatar
    Jan 2003
    Manchester
    I'm getting confused now, what format is the file in?
  11. Member classfour's Avatar
    The Heartland, United States
    Even on a 45 minute episode, keep the quality, burn it on DVD. Most brands of DVDs are $20 to $40 per hundred shipped - CDs maybe half for the equivalent type (not so for inkjet printables). Why waste an hour encoding over 20 cents (all US money)?
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  12. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Well I see your point.
    And for me are €.
    BTW, the format is in IFO files, but I want to convert them to avi.
  13. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can't have it both ways
    Read my blog here.
  14. Member PTsniper's Avatar
    Aug 2006
    Portugal
    So, what do I need to do to create a CD that is readble in every DVD player?
  15. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    VCD if you want it on a CD.
    Read my blog here.
    Jan 2004
    Middle of England
    If its 45min you could go SVCD, could even fit on a mini DVD,every player then VCD or DVD you could try DVDx.
    Also I tried AutoGK and when trying it out my virus detecter detected a virus...What was that all about.
    Oscar.
  17. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    SVCD is not universal. many players will not play SVCD based material. MiniDVD plays on even less players than SVCD.
    Read my blog here.
