My digital camera makes MPEG-1 muxed movies. Since QuickTime isn't too happy handling muxed fil,e I use FFmpegX to change to other formats.
FFmpegX is happy converting the MPEG-1 muxed files to DivX. However, it has problems transforming the files directly to iPod formats (three that are listed in Quick lists). Changing the file to DivX first, then opening it again and changing it to iPod format works (of course). Is it because the files are muxed?
I am using the latest version of FFmpegX.
I had the same problem. I had a tone of movies that were mpeg1 muxed.
I didi the following:
-Demux into a video and audio using ffmpegx
-Take the 2 files and convert them to mpg4 using ffmpegx again.
-Drop the mpg4 file into the Ipod movies section.
Worked great for me.
I know have all my movies on my Ipod as well as Quicktime Playable Mpeg files.
Best way by using MPEG STREAMCLIP to convert MPEG2 Muxed at 720 x 404 ?
By DTRON in forum Video ConversionReplies: 1Last Post: 21st May 2010, 16:22 -
MPEG-4 Muxed Audio Options
By cthompson in forum Video ConversionReplies: 7Last Post: 9th Jul 2009, 18:11 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56 -
How do I make a muxed mpeg2 data file using ffmpegx?
By tjaca51 in forum Video ConversionReplies: 0Last Post: 13th May 2007, 23:20
