Hi i have a movie with 2 avi files and 2 srt sub title files. I was wondering if anyone knew how to put all these files on 1 disc with working subs using svcd2dvd or any other programs.
You need to turn your text based subtitles to the binary .sup format. See https://forum.videohelp.com/viewtopic.php?p=1519300#1519300
Then it is this .sup file which must have the same basename as the asset (and be in the same folder).
No need to add as an asset - if it is there, SVCD2DVD will pick it up & add it as a proper DVD selectable subtitle.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Selectable?Originally Posted by ChrissyBoy
ChrissyBoy, are you saying the subtitles then become selectable as in a menu selectable option (subtitles on, subtitles off)? I always thought SVCD2DVD just hard coded the subtitles on the resulting DVD. I've always assumed this to be the case so for this reason I've always used VirtualDub to hardcode the subtitles as this allows me to choose the color and font and position of the subtitles. But if SVCD2DVD renders the subtitles as a menu selectable option that would be awsome! -
Yes, selectable...
Adding .srt to 1080p .mkv NOT WORKING!
By The_WRATH in forum SubtitleReplies: 8Last Post: 11th Apr 2020, 08:06 -
Multiple .srt subtitle files in a Divx movie
By sam9s in forum SubtitleReplies: 6Last Post: 13th Feb 2015, 16:34 -
adding srt to movie
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2008, 13:03 -
Adding srt to avi not working
By joesphroth in forum SubtitleReplies: 1Last Post: 31st Mar 2008, 12:34 -
adding subtitiles without the srt file....please look, thanks
By funkyharry in forum SubtitleReplies: 5Last Post: 28th Jan 2008, 12:43
