    Mar 2006
    Can anyone tell me the speed of a Viking 1GB cf card.
    When i put the card into my reader it said it was a Toshiba compact flash card so i take it this is who it's made by and rebaged for viking.
    i purchased this card of 7dayshop for £9.99 not that expensive so i thought i would give it a try, but it did not say how fast the card was
    i tried it in my Fuji camera and it works fine and also in my PDA witch also doubles up as a satnav
    But i am just interested to know the speed and how reliable it is, if its made by toshiba then thats not a bad price for a 1GB CF card
  2. Member blinky88's Avatar
    Mar 2004
    Australia
    USB2
    USA
    Here's a link to the Viking site. The memory chip itself might be Toshiba: http://www.vikingcomponents.com/configurator/flashDetail.asp?type=COMPACT
    If you got it for £9.99, you got a bargain. Viking is a good company.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    SanDisc as a comparison has 4 levels of Compact Flash performance. You need to get the spec sheet for your model number. Usually Level 2 and up will be on the label because they are more expensive "pro" or "pro photo" or "video" models.
    Level1 Greater than or equal to 1 MB/s (1-5MB/s)
    Level2 up to 10 MB/sec read, 9MB/s write
    Level3 up to 20 MB/sec (exceeds USB2 sustained)
    Level4 up to 40 MB/sec (exceeds USB2 sustained)
    An 8MB level 4 Sandisk CF card lists at $559.99
    http://www.sandisk.com/Products/Item(1997)-SDCFX4-8192-SanDisk_Extreme_IV_CompactFlash_8GB.aspx
  5. Member edDV's Avatar
    Mar 2004
    That Viking is a level 1 CF card. Note that transfer speeds are for burst, not "sequential" or "sustained"
    Data Transfer Rate
    Read: 3.7 - 8 MB/s Burst
    Write: 1.5 - 5 MB/s Burst
