hi,
im tring to add subtitle to a dvd movie with dvd lab pro as i always do but this time i getting a sync problem with the subtitle im adding after the project comeplete.
the out of sync is changing along the movie , at the begining everything ok and during the movie its getting out of sync .
usually when im having that kind of problem im using subtitle workshop to fix it but in this preticular movie at subtitle workshop the sync is good all the movie .
anyone know what can i do to solve it ?
thanx
is the subtitle in the right frame rate ?
because if the original video file was converted to PAL, or converted to NTSC, then you must convert the subtitles also to the frame rate target
Good subtitle sites
By mx5 in forum SubtitleReplies: 49Last Post: 1st Feb 2019, 10:55 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How to sync subtitle to another subtitle?
By mriddler in forum SubtitleReplies: 6Last Post: 1st Apr 2010, 05:07 -
Problem with font size of added subtitle in MKV file and freezing pic
By tindrli in forum SubtitleReplies: 0Last Post: 24th Mar 2010, 12:47 -
Subtitle always out of sync
By nonkeljef in forum SubtitleReplies: 3Last Post: 1st Aug 2007, 15:37
