I've installed AVICodec so that I can examine basic information about my files. But with it set to include V.Bitrate as one of the columns displayed, this is always shown as '0 Kbps'. Is this a known flaw, or am I not using it correctly?
If I open the same AVI files in GSpot or VirtualDub, their bitrates are shown.
Terry, West Sussex, UK
I've noticed that too sometimes. I don't think it's a problem with the video, but a programming error in avicodec. If I go do something else for awhile then try it again it usually shows all the information correctly. I've also noticed that sometimes it won't show the filesize of the video or audio component. This too I believe is just a simple programming error. But usually it works correctly.
Good luck.
Why doesn't handbrake re-encode show video bitrate in MediaInfo?
By KushSmoka420 in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 15:55 -
subtitle doesn't show in MPCHC
By alexanderex in forum SubtitleReplies: 2Last Post: 28th Feb 2011, 20:45 -
Why MPCHC doesn't show up in the right-click submenu ?
By mahogany in forum Software PlayingReplies: 7Last Post: 12th Dec 2010, 16:23 -
DVD Menu doesn't show
By miki22 in forum Authoring (DVD)Replies: 1Last Post: 19th Mar 2009, 17:17 -
Video TS folder doesn't show up after DL.
By crowheart in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2007, 10:56
