Hi,
I get error message when trying to burn a DVD with Decryptor. What does it mean?
Thank you!
This usually means the copy process stopped because the writer ran out of data (connection lost to the pc) or the file you want to copy might contain corrupt data. (I got that from a couple of sites.)
Make sure DMA is enabled for the drive. 'It could be PIO mode. You can check it in 'Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI Controllers'. Look at 'Properties>Advanced Settings' and it should show DMA modes for all drives. If you see PIO, right click on that channel and 'Uninstall', then reboot and check.'
Also it could be the source file is corrupted or you have something running in the computer that jumped in and stopped the data flow. -
Thank you for advice. I browsed various Web sites since the time I posted and it is exactly what you advise.
Thanks again.
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Invalid Public Atom
By Michael Boutros in forum ffmpegX general discussionReplies: 3Last Post: 22nd Apr 2009, 13:26 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 23:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19 -
Invalid Location
By Justgrant2009 in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2007, 19:48
