I would like to create and make available for download a screensaver that displays in full screen the url to my Infinite Car Show. Does anyone know of a program or way to do this? Freeware?
www.google.com.au/search?hl=en&q=create+screensaver+free&meta=
There's loads of likely candidates in that list...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Garibaldi,
At least in windows, a screensaver is an executable file, so it would be able to use the WebBrowser control (for one method) to do what you want. If you're a programmer, you should be able to do it yourself. If you're not a programmer, or just don't feel like the work, this google search would be a good place to start. -
I've put together a beta of what I want to do which you can download and try out. Unfortunately the program I'm using to make this one puts their label on it as well as won't let me disable that white box or scrollbars around the edges. If I could just do that it would be perfect
WCC Screensaver Beta 1 -
I recall using Blue Metal Screensaver Factory in the past and I believe it allows you to insert a URL that is clickable. I'm pretty sure it wasn't freeware though.
If you take a look at the link I posted you'll see what I mean, the url should fill the entire page. Does anyone have any ideas of freeware to do this?Originally Posted by Poppa_Meth
Is [url]http://videodownloader.net[/url] safe ?
By pchan in forum Video Streaming DownloadingReplies: 3Last Post: 12th Mar 2009, 00:02 -
[url]www.youconvertit.com[/url] will convert most files
By Topp in forum Video ConversionReplies: 12Last Post: 21st Feb 2009, 18:58 -
Trouble with avidemux and [url]www.debian-multimedia.org[/url]
By Verlager in forum LinuxReplies: 24Last Post: 1st Dec 2008, 23:27 -
is it just me or has [url]http://www.rpc1.org/[/url] been awol for awhile?
By aedipuss in forum DVD & Blu-ray WritersReplies: 11Last Post: 31st Dec 2007, 00:19
