    Jan 2004
    what is an editing card, and do I need one?
  2. Member OmegaSupreme's Avatar
    Oct 2003
    Fort Lauderdale
    Editing cards usually provide hardware acceleration for special effects and other digital manipulations.
    If you have to ask, then you don't need one.
    Jan 2004
    you mean like when doing an external preview how it plays back slowly, or choppy sometimes? The editing card makes it play frame for frame (even with a lot of effects) ? How much are they?
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Realtime effects usually require multiple RAID streams usually from a central server.
    This is what separates the big guys from us "sumers".
    Lowest entry examples are like the Canopus Edius (with hardware)
    http://www.canopus.com/products/nlesystems.php
    or the Matrox RT.X100 Xtreme Pro or Matrox RT.X2
    http://www.matrox.com/video/products/rtx100xtremepro/home.cfm
    http://www.matrox.com/video/products/rtx2/home.cfm
    At the little guy level, effects are usually processed in software non-realtime and the speed depends on CPU power. Vegas adds the ability to assign a render task to several CPUs over a network as one way to speed things up.
