Hi,
I am trying to open the sript in VirtualDub:
MPEG2Source("C:\Documents and Settings\Owner\Desktop\Ladykillers-Test.avi")
function LimitedSharpenFaster(ss_x=1.25,ss_y=1.25,Smode=4,s trength=600,soft=30)
Soothe(sharp,dull,25){}
and receive error message:
Avisynth open failure
Script error: expected a , or )
(C:\Path\To\filename.avs, line 2, column 35)
What's wrong in the script?
Thank you!
Results 1 to 30 of 53
Originally Posted by vertical
Is LimitedSharpenFaster really a function, or is it a plugin?ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Thank you!
I am not sure but I believe you gave a clue. What if it is like this?
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DGDecode.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MaskTools.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MT_MaskTools.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\RemoveGrain.dll")
dull=last
Sharp=LimitedSharpenFaster(ss_x=1.25,ss_y=1.25,Smo de=4,strength=150,soft=30)
Thanks!
I tried this one and it looks like it is OK but it requires d2v file instead of avi. Probably I can use DMPGDindex to create d2v from avi though not sure whether it's possible. -
It looks like there is a mistake.
It should be DirectShowSource for avi instead MPEG2Source, right?
But now it gives another error message... -
Load your plugins before you load the movie. DGDecode needs to be loaded before MPEG2Source is called, if the file is an mpeg. Also, you need to create the d2v files and load that instead.
If it is an avi, then either DirectShowSource or AVISource should be used instead of mpeg2source. Also, if it is an avi, you probably don't need to load DGDecode.dll
It is good practice to load all the plugins etc first, before doing anything else int he script.Read my blog here.
It means put all the LoadPlugin lines (the ones with the DLLs) before the Source line. It'll make a big difference if you're using MPEG2Source, as it can't be used until you load the plugin for DGDecode.dll. It's standard practice. If your source is an AVI, use AVISource (or DirectShowSource if that doesn't work), and you don't need to load the DGDecode.dll at all.
And stop doing this:
function LimitedSharpenFaster.....
How many times do I have to tell you it's:
LimitedSharpenFaster..... -
Should it be this way?
DirectShowSource("C:\Documents and Settings\Owner\Desktop\Ladykillers-Test.avi")
dull=last
LimitedSharpenFaster(ss_x=1.25,ss_y=1.25,Smode=4,s trength=150,soft=30)
"How many times do I have to tell you it's..." - Sorry about this. But I do not remeber you telling me about it -)
Hi-
I don't even understand why what you had works for you. Always test by opening in VDubMod before sending to your encoder. This should be enough:
LoadPlugin("C:\Path\To\DGDecode.dll")
MPEG2Source("F:\Documents\Temp\moviename.d2v")
LimitedSharpenFaster()I meant that you had this:
function LimitedSharpenFaster(){} -
manono, thank you.
Yes, I do remeber this but I did not even know about the thing. I mean "to load plugins" and did not realize the order of lines is of importance but now I know.
I do not have Southe avsi. Will it be a big deal if I remove the last (Southe) line? Or I can create the avsi I you could please afvise what should stick in it.
Thanks. -
I'll link to the Soothe thread where you can find the Soothe function, for the 3rd time now:
http://forum.doom9.org/showthread.php?t=99679&highlight=Soothe -
Oh, sorry, but I forgot something. The script you posted wasn't quite right. You do it like this:
Dull=Last
Soothe(Sharp,Dull,25)
Soothe needs the unsharpened video (Dull) and the sharpened video (Sharp) in order to do its thing. The way you had it before won't work.
And that Soothe setting actually removes most of the sharpening (read the thread to which I linked). I work with mostly old films which are kiind of shakey to begin with. I don't want LSF to make them any shakier, so my Soothe setting is kind of strong. If you have a nice clean new video, then you may not need Soothe at all, and the Soft setting should be plenty. About all you can do is test. I noticed in a previous script you had the strength set for 600. I'm not saying that's bad, but if you start to get artifacts in the form of jaggies/aliasing/shimmer, either increase the Soft setting, back off the Strength setting or both. Or put on Soothe.
Edit: you posted before I got in my clarification. If what I said to do doesn't get it going, please post your full script. -
manono, thank you.
It looks I am missng something. I still get error message. Here is the full script:
Dull=Last
Soothe(Sharp,Dull,25){}
How can I disable Soothe in case I deal with a new good quality movie? Just to change 25 to 0?
As for Strength=600 I set it this way just to try. -
First, remove that {} after Soothe. Now try.
If that doesn't make it work, although I don't seem to need it, the script in the thread says to do it this way:
Dull=Last
Sharp=Dull.LimitedSharpenFaster(ss_x=1.25,ss_y=1.2 5,Smode=4,strength=150,soft=30)
And if that doesn't make it work, then drop Soothe. To use LSF without Soothe, then:
Leaving off the Dull and Soothe lines. If that doesn't make it work, then a name or path must be screwed up. The error message should tell you the offending line.
Edit: There's always the chance you have a colorspace issue. Pay attention to the error message, if there is one. DVDs are always YV12. AVIs can be any old thing, I think. Not really sure, as I work mostly with DVD, unless I'm using an uncompressed Lagarith AVI. -
I tried all variants but it does not work.
Depending on the variant, different error messages. If full script with Soothe: there is no function called "SimpleAverage" (Xe...line 77)
C:.........line 6
Color was never mentioned in error messages.
Could be that I screwed the Soothe.avsi and this causes it? -
No, it does not if I remove
Dull=Last
or with it. -
Thanks.
The full error message is
script error: there is no function called "SimpleAverage" (Xe...line 77)
C:\Path\To\line 6
But LFS works with builtin Sharpen. Doesn't it mean it is fine? -
Here it is in full as the last version advised by manono:
Dull=Last
Or you probably mean line 77 in LSF.avsi, don't you? -
Does :
by itself work?
And did you make sure to get the right version of MaskTools? There's a bunch of them.
Here's a thread that lists what you need and where they can be found. Make sure you have the right ones:
http://forum.doom9.org/showthread.php?t=115727
Edit: I was looking for the same thing, guns1inger.
Also, what version of AviSynth are you using? Make a Version.avs and inside put only this line:
version() -
This is probably worth a read
http://forum.doom9.org/showthread.php?t=115727Read my blog here.
I've got the following:
MT_Masktools 2.0.30.0
Masktools 1.5.1.0
manono, you are dealing with a newbie. I do not understand what "Does LimitedSharpenFaster() by itself work?" means. How should it work by itself?
Really sorry. -
It has to be MaskTools 1.5.8.
I meant, if you put:
LimitedSharpen()
in the script, without all that other stuff inside the parenthesis, does it work?
Probably not, if you have the wrong version of MaskTools. It also has to be the correct version of RemoveGrain. Get them both from that last link guns1inger and I gave. -
I will replace the masktools right now and will try again.
No, when I removed everything (Soothe, etc) as you advised it did not work.
AviSynth open failure in VirtualDub
By fatcharlie in forum Newbie / General discussionsReplies: 5Last Post: 3rd Mar 2011, 21:32 -
Avisynth question open failure FF3TdGPU.dll
By duster1234 in forum Video ConversionReplies: 4Last Post: 15th Oct 2008, 07:29 -
AviSynth open failure:
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 29th Jul 2008, 20:35 -
Avisynth open failure for cropping
By php111 in forum Newbie / General discussionsReplies: 51Last Post: 26th Mar 2008, 12:24 -
AVIsynth failure in VD
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2008, 04:08
