While using Video Redo for authoring vob/mpg files, I noticed the following serious probems.
I have opened a movie file with video redo to check for its compatibility. After closing the program I found that all the files in source folder have simply disappeared. Can anybody tell me how to fix this. How the program can delete the source files without the option in the settings. Even after simple viewing of a file, the file gets deleted after closing the program.
The only time I've heard of VideoReDo deleting any files (including source files), has been due to the use of a cracked version.Originally Posted by Phaneendra Rao
Where did you obtain VideoReDo from? Have you purchased it, or are you using it as a trial? Presumably you downloaded it - was this from the VideoReDo website? -
Does it edit out commercials easily? Do you have to set it up to edit the commercials, or point to where the commercials are located by a timeline type of thing, or does it automatically edit them out by some great subroutine that finds them?
You can set it to automatically detect commercials. I don't know how accurate it is because I've only experimented with that function, but it does work. I believe it detects the black video before & after a commercial. I've always manually scanned in order to make sure I cut exactly where I want. Basically I use either the fast scroll bar or slow scroll bar in order to quickly scan through the video's timeline & watch for the commercials. That's usually fairly quick because commercials are pretty easy to pick out because they typically last several minutes.
Question about Video Redo
By snafubaby in forum EditingReplies: 6Last Post: 26th Feb 2012, 04:01 -
Anyone used Redo backup??
By ranchhand in forum ComputerReplies: 5Last Post: 2nd Oct 2010, 23:11 -
AGK and Video-redo not recognizing my HDTV files...?
By OrangeTTT in forum Video ConversionReplies: 17Last Post: 10th Dec 2008, 01:34 -
GUI for DVD and Video Redo both crash Win2k
By Skarr11 in forum Authoring (DVD)Replies: 1Last Post: 20th Jul 2007, 17:02 -
Redo chapters in a DVD
By zakman in forum DVD RippingReplies: 1Last Post: 24th Jun 2007, 15:19
