Results 1 to 18 of 18
    Mar 2006
    Uhoh!
    After many months of happy work my SVCD2DVD is crashing:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Runtime.InteropServices.COMException (0x80004005): Unspecified error
    at QuartzTypeLib.FilgraphManagerClass.RenderFile(Stri ng strFilename)
    at x3284ccece41ee22b.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
    at x3284ccece41ee22b.x210ff09a2516b1a7.x92b839eef7ea4 c46(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly Version: 2.1.2308.33338
    Win32 Version: 2.1.2308.33338
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    DevComponents.DotNetBar
    Assembly Version: 5.6.0.0
    Win32 Version: 5.6.1.9
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    Accessibility
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Interop.CodeLock
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
    Interop.DexterLib
    CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    Have just uninstalled and reinstalled with the latest stable version of the registered version.
    Any ideas?
    Andy
  2. Error may be more related top your .NET framework. Try un/re-installing latest version of it?
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    When is this happening? When you preview a title or when you start the program?
    Mar 2006
    When I launch the application, it gives me quit or continue... I have just clicked continue and it seems OK???
    Can't get into the config menu though (get the same error), but everything else works?
    Have just created a DVD to check it and it does seem to work.
    Weird!
    Still get the error on startup and trying to get into the options...
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    It is to do with the preview window. Something has changed on your system (in regards your codecs). When the program starts it plays the splash.mpg file.... it is this that is causing the problem. If you try to play the file in WMP you will have the same issue. Can you confirm?
    Mar 2006
    You are correct!
    My WMP seems incapable of playing that file type... only Quicktime will play it.
    How weird!
    Any suggestions on how to fix it?
    Which particular codec is that using?
    Andy
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    It is mpg1. Reinstall WMP perhaps?
    Mar 2006
    Ok, did that (surprised I could actually as I refuse to accept WMP10).... and nothing
    Same error in wmp
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Well you could install http://www.xpcodecpack.com/
    but you probably only need : https://www.videohelp.com/tools?tool=GPL_MPEG-1_2_Decoder
    Remember that after you install new codecs you will need to reboot for Windows/WMP to use them.
    Mar 2006
    Well, I've tried:
    1) Those codec packs
    2) Other codec packs
    3) Upgrading to WMP10
    4) Reinstalling directx
    Using Sherlock to look at my video codecs the MPEG one is quartz.dll which is part of DirectX
    I wish I knew wtf was wrong with this
  11. I have the same probelm. My investigations lead me to suspect the install of Cyberlink PowerDVD. I suspect its also scuppering my ability to import MP3s into Windows Movie Maker 2.
    This thread seems related:
    https://forum.videohelp.com/viewtopic.php?t=307655&start=0&postdays=0&postorder=asc&hig...%20mpeg%20play
    I'm trying a few things to see if I can resolve this and I'll post my findings here.
    Mar 2006
    Yeah its really starting to get me annoyed now!
    I've also checked and replaced a copy of quartz.dll manually (from a friends PC).
    I think my trouble started when I installed a very old game called "Starship Titanic" and it had some cranky old shit mpeg video software with it
  13. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok you have the GPL MPEG-1/2 Decoder codec installed. Now try upping the merit for it using DirectShow Filter Manager:
    Then reboot.
    Mar 2006
    Tried that Chris, nope, still no go
  15. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    And it still won't play in WMP? Have you got another MPEG1 or MPEG2 file you can try in WMP?
    Mar 2006
    Yep, got loads of MPEG1 files here...
    All play fine in Quicktime...
  17. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    And WMP?
  18. Member
    Mar 2006
    In WMP, nope, nada, none, zero, zip...
