These dvd´s models haven output of 720 via component at least that is what attached figure
shows.
Am I right?
If so I intend to attach one of this to a Projector at the component in and obtain 720p image for playing dvd films commercial I mean Blockbuster and so on.
The first is produced in Australia and the other in Brazil.
Could somebody comment to make me clear this?
Thanks.
I can't find good specifications for that model.
If you want a DVD player for progressive output to a projector, first make sure it has high quality hardware deinterlacing with "cinema" inverse telecine processing. That is the most basic function for progressive DVD player quality. That will get you first 480p over analog component in most models.
Next best feature assuming a progressive projector is digital DVI or HDMI output at 480p.
Then lastly next best feature is upscale in the player from 480p to 720p. Most displays or projectors will do this internally from 480p to native display resolution so it may be a wasted feature.
Put highest priority on the deinterlacer quality in the player.
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
