Hey! Can anyone suggest an authoring program that has a build in deinterlace feature (for buring to later play on standalone DVD players)?
Thanks!
Results 1 to 9 of 9
No need to deinterlace in software for a standalone player. Progressive players have hardware deinterlacing.
Why would you want to extend authoring times and lower quality? -
Originally Posted by edDV
Deinterlacing is more work for the conversion program and deinterlacing lowers the quality of the video.
Interlaced video is the native state for standard definition (and 1080i high definition) TV. If your source is interlaced and your making a DVD, leave it interlaced. -
I guess what I was trying to say is that my MPEG-2s have interlaced lines. When there is movement, the picture looks bad. I am under the impression that by using a deinterlace filter, that will clean up the video.
If your TV is interlace, there is no need to deinterlace. You will only be extending encoding times and lowereing quality.
If your TV is progressive, it is the job of the progressive DVD player to hardware deinterlace or inverse telecine interlaced sources. Make sure you invest in a progressive player that has high quality hardware deinterlacing with "cinema" inverse telecine processing. -
Okay, so I shouldn't be worried about the interlaced lines that appear on my computer. That the standalone DVD should take care of it (if it's progressive scan)?
Originally Posted by christopheramos
a standard 480i DVD player can feed a progressive TV as 480i (best over YPbPr) and the progressive TV can inverse telecine or deinterlace.
If you have a cheap HDTV (i.e no "cinema" inverse telecine) get a good progressive DVD player with that feature.
As far as computer playback, use a good deinterlacing software DVD player like VLC (free) or PowerDVD or WinDVD that often come packaged with DVD players. These players will eliminate the line split during motion.
This way you preserve the original quality of the original 480i video file. As an alternative, you can software deinterlace for extreme compression but you may want to keep an interlace backup at higher quality if the file is important to you.
Authoring programs
By countmonster in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2011, 07:59 -
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 13:53 -
Recommended DVD authoring programs...
By mjl1297 in forum Newbie / General discussionsReplies: 23Last Post: 18th Feb 2010, 21:14 -
Authoring programs for Mac
By turbochargedRS in forum MacReplies: 8Last Post: 12th Mar 2008, 23:42 -
The best Converting/Burning/Authoring programs?
By whatever911 in forum Authoring (DVD)Replies: 11Last Post: 23rd Jul 2007, 14:01
