I get the same message too.
I previously use mpack but recently have problems with pixellation-really bad ones too.
I've encoded a mov file with cleaner 5 with the toast compatible option checked yet toast does not recognize the encoded .mpg file. Help!
Mpack generates an encoded file with this suffix : .mpeg_tr
Cleaner file generates an encoded file with this suffix :
.mpg
Is that the problem? Am I missing an extension?
Read that i need to remux/demux the cleaner mpeg file before toasting. Is this true? How do I do this? In Astarte's WiredMux?
papasmurf, open the source MPG with some MPG analyzer and check if it has the correct size and bitrate
pb400, if you encode with Cleaner 5, Toast 5 WILL accept the MPG. Make sure that :
1. You're applying the standard VIDEO CD NTSC or VIDEO CD PAL Cleaner template on the file to be encoded. If you alter any parameter from this template, like size or bitrate, the result could not be VCD compliant.
2. Your Toast should not be a beta version (read the file information)
Toast 5 should accept the resulting MPG no matter the Toast or Whitebook option was checked in Cleaner.
<font size=-1>[ This Message was edited by: major on 2001-08-02 03:53:47 ]</font> -
On 2001-08-02 08:12:38, g_fahr wrote:
you have to set toast more memory - thatīs all !
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
It could be memory, perhaps, but this is also the standard message Toast gives when you present it with a non-recognized MPEG I format file. Toast is very particular about the MPEG files it takes; I've had no problems with Cleaner's Toast-ready and M.Pack's Toast-ready options. Double-check your MPEG-1 settings, choose Toast compatible if you can when encoding. -
I got the same error message. What you need to do is multiplex it with TMPGE in Virtual PC. Under Mpeg tools in TMPGE there's an option to multiplex. I export all my movies in quicktime to .avi's and then encode them in TMPGE... Making sure the size is 352 x 240... Then multiplex them with TMPGE.... Drop them on toast and burn...
It works...
Toast "An error has occurred recompressing the video"
By trevytrev in forum MacReplies: 12Last Post: 25th Feb 2015, 16:47 -
Sense Key = Medium Error sense Code = 0x73, 0x03 in Toast
By arythmic in forum MacReplies: 37Last Post: 27th Nov 2012, 18:46 -
Toast 9: The drive reported an error
By soundchaser in forum MacReplies: 16Last Post: 1st Jul 2009, 14:55 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 12:46 -
LaCie / Toast / DVD+R DL Error
By webstar in forum MacReplies: 6Last Post: 4th Aug 2007, 11:53
