hello ,anybody can help me to solve these following problems ?I am really need your help
1.how to use an object function in VB 6 ? for instance:
2.if i want to use only one dialog box to display all my items?like i press one button,it show me the picture,then i press another button,it shows me another picture but at the same frame box.
3.how to use OLE scroll function in vb?like i want to automatic play pdf files.
4.how to show a JPEG picture by using vb code?
If you google and look at some of the many programming resources you will find example code and tutorials for all of this.
Try somewhere like this - http://www.codeproject.com/ - for startersRead my blog here.
yes.
at first thanks for your reply ...
but before i post the question here ,i have already done some searching on web,it is really not so related to my objective when i get the searching result...
I hope you can give me some direct suggestion. thanks very much. -
I have found the MSDN manuals to be of great assistance when using visual studio 6, and in particular, VB6.
You could also try:
http://msdn2.microsoft.com/en-us/vbrun/ms788232.aspx
http://msdn.microsoft.com/library/en-us/dnanchor/html/vb6anchor.asp
http://vb-helper.com/
http://www.vbcity.com/
http://www.vbforums.com/forumdisplay.php?forumid=1If in doubt, Google it.
sony DAV-HDX589W multi code zone code
By sam1821 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th May 2010, 15:37 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37 -
HTML code suitable for different sized Monitors; also code to embed
By wiseant in forum Off topicReplies: 3Last Post: 8th May 2008, 18:14
